Logging
/ Logging #1
Lloyd_E
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
Helped my good friend do some logging yesterday. Harvested locust trees.
He will mill them into posts and building material at a later date. Some of the longs were over 50'+ long. We also helped his neighbor place some long pine logs into position for a slip way to haul his floating wharf out after the boating season. First time on the beach with tractor was a little worried about getting stuck with a rising tide.
The 3pt hitch worked flawlessly - lifting everything we threw at it! We figured some logs to be close to a 1000lbs.
Last image is of him. We had a great evening - first night able to sit outside by the fire.
The wives enjoyed the evening too!
Lloyd
/ Logging
egon, You're right - about the only good use. I guess in its time it was better than a fireplace with open hearth cooking. I guess the next best use would be a mooring - incasing it in concrete of course!
lloyd
/ Logging #4
I'd say by the pictures a few of those logs were way over 1000lbs? locust is a dense wood and can be heavy as heck. Works great for building wish I could come up with some more.
/ Logging
Thanks 2020.
You guess is more accurate than mine. Is there a formula for figuring it out?
Most of the trees came off his property. But there are many more in the area to be collected. His neighbours are more than happy to let him cut them down and haul them away.
lloyd
/ Logging #7
some people don't realize that locust is one of the best firewoods out there so if people are happy to let you cut it down - get it.
/ Logging
dking,
My buddy is intent on building something with it. Knowing his schedule - and this is not to negate him, he is an extremely busy guy - I keep telling him I see a pile of firewood. He says it is locust and will keep for a long time as a log and will eventually get around to dealing with it:) :) :)!!!!
I am taking all of the limbs and twigs to make twig furniture - eventually!!!!
lloyd
/ Logging #9
Lloyd, it's kinda a long drive, but I would have loaned you my grapple to handle those logs.;) Nice job! What was the temperature? That's what I'm the most jealous of.:rolleyes:
/ Logging #10
Thanks 2020.
lloyd
Here's one someone posted here some time back, easy to use, but don't know if it figures green or seasoned.
Log Weight Calculator at WOODWEB
/ Logging
milkman,
Thank you. Very interesting site. I visited it years ago and forgot about it.
Rough calculation based on 8" dia at small end and 18" dia at large end with 27' of length equates to over 2000lbs. Even at half that weight it is impressive.
jinmna,
We are actually experiencing summer. The weather was about 73 Fahrenheit with a cool breeze off the water. It was very comfortable to work in. And any time I was in the tractor the AC was on.
Evening was wonderful - stayed around 65 Fahrenheit. Of course the fire helped a bit and the wives didn't complain too much.
lloyd
/ Logging #12
You can also go to the forestyforum they have a log weight calculator. I use the straight logs for lumber and the "junk" for fire wood, burns great.
3-gal. chemical inductor, Coal Valley, IL (A65640)
3-gal. chemical...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
