LOG SPLITER BUILD
/ LOG SPLITER BUILD #41
THis maybe a better option
That would work but obviously you lose the auto cycle. Most people who want the autocycle and lift/four way cylinders end up using two rd25xx prince valves.
Here's mine
The pump supplies the lift/four way valve on the left first. And then the PB from that valve feeds the auto cycle. Each valve has a return to the tank.
And here's how I did the dump valve.
/ LOG SPLITER BUILD
Here's mine
Very nice job on your log spliter. Very good photos it's defiantly an inspiration.
/ LOG SPLITER BUILD #43
I put a log lift on home-made splitter and I think the cylinder has only about 8" stroke. I find myself feathering the valve while lifting a 2' round oak to slow it down some. I can't remember the rod size now but it's small. I'd have to go measure it to be sure at this point.
/ LOG SPLITER BUILD
1456358655919.jpg1456358667150.jpg1456358676229.jpg1456358685866.jpg1456358695910.jpg1456358721129.jpg
Finally got the log lift built. Used 2x2 1/8" thick for the frame. 3" bore cylinder 8" stroke
/ LOG SPLITER BUILD #47
Nice job on the mounting plate and getting things lined up
/ LOG SPLITER BUILD
So I got it all together had a few leaks to fix but not too bad. The log lift has just the right speed 3/8 hose.
I'm not sure about the wedge I put a big piece of wet maple 2' diameter had to turn the pressure up to 3000psi and it popped right through.
My question is should I cut some of the top of the wedge out so it will start the the split on bottom first ?
/ LOG SPLITER BUILD #49
No on the wedge mod. If anything, do the opposite so it splits top first. That way the piece don't ride up.
/ LOG SPLITER BUILD
I going to play with it some more before I do anything. Video coming soon
/ LOG SPLITER BUILD
So I had a few bugs to work out. For example my wedge didn't work out so I completely removed it re shaped it was just to much surface area it would split but it was hard. Then the starter when bad had to order and wait on that. Finally got all together and so far I'm very pleased split a good truck load of wood no problem. The log lift is the best part it works great.
Any way here is a link to the YouTube video
Log splitter - YouTube
/ LOG SPLITER BUILD #54
Looks like it is working well.
Lifting and splitting some pretty big stuff with ease
Caterpillar 631 Scraper Service and Parts Manuals (A63117)
Caterpillar 631...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
