locked up 4wd
/ locked up 4wd #1
Tul01
Manitoba, Canada
2015 John Deere 5115M, 1928 and 1945 hand start John Deere D's,
Hi guys, trying to help my dad here, so the info might be a little vague until I get out this weekend to have a look. He has a 2000 Polaris Expedition 425, 5 speed manual 4wd. (not very common)This week he put it up on jack stands to check the speedometer and discovered it won't come out of 4wd. The switch makes the light work properly and he says it appears the power is going to the proper places. I was wondering if anyone knows if the front diff is that basket style like on my Ranger. He said its built into the bottom end of the tranny so he didn't want to start tearing it apart until we can diagnose it a little further. The orig problem was the speedo/odo quit counting(lights up and appears to work but doesn't), could this all be related to the sensors that Polaris uses to get the 4wd to cut in? Shouldn't you be able to just switch off the 4wd regardless of the wheel slippage sensor? Thanks Hopefully we will be able to figure this out this weekend. Does anyone know where to find a manual for this thing. It came with a 3 page insert into a different model manual.
Brent
/ locked up 4wd
Just thought I would post what we found out. The speedo issue was the sending unit on the hub. Quick to replace. The 4wd issued turned out to be that the plastic basket hub on this model of polaris is in each hub, (not the diff like my Ranger) and had never been serviced. The oil and crud in them was not letting them disengage. Flushed them out and added some fresh oil and all was good. The Polaris guru he talked too recommended flushing once per year even if like my dad, it rarely sees mud and even less time in 4wd.
Brent
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
2023 John Deere 8R 340 Tractor (A63111)
2023 John Deere 8R...
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
