Oil & Fuel Lock N Lube
   / Lock N Lube #2
I have had it for about 6 months, works great for my needs. I only have the one tractor and assorted implements .
   / Lock N Lube #3
Check out Lube Shuttle. It has a zerk lock similar to locknlube also. Works awesome.
   / Lock N Lube #4
great investment . I grease alot of equipment and It saves alot of time
   / Lock N Lube #5
I bought one. Found it cumbersome, messy, bulky and time consuming.
Bought another type, can't remember the name. Less messy, less bulky, still time consuming.
I mailed them both to Murph.
   / Lock N Lube #6
And they both work fantastic thank you Brother Richard!
   / Lock N Lube #7
I got one and put it on my Dewalt grease gun. Both work great. And because it is a lot easier with the electric gun, I tend to use it more.
   / Lock N Lube #8
You're very welcome!!!
Merry Christmas Brother Murph!!! :santahat:
   / Lock N Lube #9
I also use a Dewalt gun.
If you do a lot of greasing and want to do one thing to improve that condition, buy a battery powered gun. :)
   / Lock N Lube #10
I bought both a Lock-N-Lube and Univer-Co. The Univer-Co is nearly the same size as a regular gun end and was supposed to be easier to use. Didn’t turn out that way. Most of the time it was difficult to remove. The Lock-N-Lube can be difficult to remove if a fitting won’t take grease and my Milwaukee electric pumps up to its rated 10,000 psi.
2017 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52707)
2017 CATERPILLAR...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2009 Ford F-250...
2019 International DuraStar 4300 2,000 Gallon Water Truck (A55852)
2019 International...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
2008 Caterpillar 305C CR (A53317)
2008 Caterpillar...
Terminator 3pt 60 Gal Blower Sprayer (A53317)
Terminator 3pt 60...
