Oil & Fuel Lock N Lube
   / Lock N Lube #2
I have had it for about 6 months, works great for my needs. I only have the one tractor and assorted implements .
   / Lock N Lube #3
Check out Lube Shuttle. It has a zerk lock similar to locknlube also. Works awesome.
   / Lock N Lube #4
great investment . I grease alot of equipment and It saves alot of time
   / Lock N Lube #5
I bought one. Found it cumbersome, messy, bulky and time consuming.
Bought another type, can't remember the name. Less messy, less bulky, still time consuming.
I mailed them both to Murph.
   / Lock N Lube #6
And they both work fantastic thank you Brother Richard!
   / Lock N Lube #7
I got one and put it on my Dewalt grease gun. Both work great. And because it is a lot easier with the electric gun, I tend to use it more.
   / Lock N Lube #8
You're very welcome!!!
Merry Christmas Brother Murph!!! :santahat:
   / Lock N Lube #9
I also use a Dewalt gun.
If you do a lot of greasing and want to do one thing to improve that condition, buy a battery powered gun. :)
   / Lock N Lube #10
I bought both a Lock-N-Lube and Univer-Co. The Univer-Co is nearly the same size as a regular gun end and was supposed to be easier to use. Didn’t turn out that way. Most of the time it was difficult to remove. The Lock-N-Lube can be difficult to remove if a fitting won’t take grease and my Milwaukee electric pumps up to its rated 10,000 psi.
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
1988 KENWORTH T800 DUMP TRUCK (A57192)
1988 KENWORTH T800...
Case IH Magnum 200 (A53317)
Case IH Magnum 200...
SET OF 60" SKID STEER QUICK ATTACH PALLET FORKS (A57192)
SET OF 60" SKID...
2015 Goose Neck Cattle Trailer (A56469)
2015 Goose Neck...
(APPROX.104) UNUSED 2X4X8 PRIME GRADE LUMBER (A57192)
(APPROX.104)...
