Oil & Fuel Lock N Lube
   / Lock N Lube #2
I have had it for about 6 months, works great for my needs. I only have the one tractor and assorted implements .
   / Lock N Lube #3
Check out Lube Shuttle. It has a zerk lock similar to locknlube also. Works awesome.
   / Lock N Lube #4
great investment . I grease alot of equipment and It saves alot of time
   / Lock N Lube #5
I bought one. Found it cumbersome, messy, bulky and time consuming.
Bought another type, can't remember the name. Less messy, less bulky, still time consuming.
I mailed them both to Murph.
   / Lock N Lube #6
And they both work fantastic thank you Brother Richard!
   / Lock N Lube #7
I got one and put it on my Dewalt grease gun. Both work great. And because it is a lot easier with the electric gun, I tend to use it more.
   / Lock N Lube #8
You're very welcome!!!
Merry Christmas Brother Murph!!! :santahat:
   / Lock N Lube #9
I also use a Dewalt gun.
If you do a lot of greasing and want to do one thing to improve that condition, buy a battery powered gun. :)
   / Lock N Lube #10
I bought both a Lock-N-Lube and Univer-Co. The Univer-Co is nearly the same size as a regular gun end and was supposed to be easier to use. Didn’t turn out that way. Most of the time it was difficult to remove. The Lock-N-Lube can be difficult to remove if a fitting won’t take grease and my Milwaukee electric pumps up to its rated 10,000 psi.
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
(10) UNUSED SDLANCH 2.5CM X 2 MM RATCHET STRAPS (A57192)
(10) UNUSED...
UNUSED FUTURE XJ3T-3T HYD THUMB CLAMP (A57193)
UNUSED FUTURE...
UNUSED FUTURE POLYTHYLENE PROTECTION PAD (12 PCS) (A57193)
UNUSED FUTURE...
2017 Ford Taurus Sedan (A55853)
2017 Ford Taurus...
