Loader Loader losing lifting ability
/ Loader losing lifting ability #1
forest grump
The loader on my Kioti LK2054 is losing its lifting capacity, I have had the machine for about 10 years, the hour meter never worked when I bought it, at that time it had 250 hrs on it, I would guess it has about 1500 hours on it now, no sign of any leaks.
Thank for any help
/ Loader losing lifting ability #2
others, myself included, have had issues with the seals blowing out. New seals are about $25.00 per cylinder, if you have the right tools, takes about 1hr to remove cylinder, rebuild and replace.
/ Loader losing lifting ability #3
Since there are no leaks, you might need to get a gauge and check your hydraulic pressure.
/ Loader losing lifting ability #4
I'm sure by now you've checked the level of hydraulic fluid? No horrible grinding noises? Any new noises? I'm guessing seals or pump, but I'm much more of an operator than a mechanic.
/ Loader losing lifting ability #5
There is the relief valve that could be leaking as well. I would check it before the pump if you have pressure problems Dirt or sticky valve would bleed off pressure causing your symptoms
CLUBCART CART (A66091)
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
2019 VOLVO VNL760 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2019 VOLVO VNL760...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2015 Mercedes-Benz C300 Sedan (A64557)
2015 Mercedes-Benz...
