Loader Loader losing lifting ability
/ Loader losing lifting ability #1
forest grump
The loader on my Kioti LK2054 is losing its lifting capacity, I have had the machine for about 10 years, the hour meter never worked when I bought it, at that time it had 250 hrs on it, I would guess it has about 1500 hours on it now, no sign of any leaks.
Thank for any help
/ Loader losing lifting ability #2
others, myself included, have had issues with the seals blowing out. New seals are about $25.00 per cylinder, if you have the right tools, takes about 1hr to remove cylinder, rebuild and replace.
/ Loader losing lifting ability #3
Since there are no leaks, you might need to get a gauge and check your hydraulic pressure.
/ Loader losing lifting ability #4
I'm sure by now you've checked the level of hydraulic fluid? No horrible grinding noises? Any new noises? I'm guessing seals or pump, but I'm much more of an operator than a mechanic.
/ Loader losing lifting ability #5
There is the relief valve that could be leaking as well. I would check it before the pump if you have pressure problems Dirt or sticky valve would bleed off pressure causing your symptoms
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A64557)
2017 Forest River...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
JCB 3TS-8T SKID STEER (A65053)
JCB 3TS-8T SKID...
213137 (A64276)
213137 (A64276)
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
