Loader Loader losing lifting ability
/ Loader losing lifting ability #1
forest grump
The loader on my Kioti LK2054 is losing its lifting capacity, I have had the machine for about 10 years, the hour meter never worked when I bought it, at that time it had 250 hrs on it, I would guess it has about 1500 hours on it now, no sign of any leaks.
Thank for any help
/ Loader losing lifting ability #2
others, myself included, have had issues with the seals blowing out. New seals are about $25.00 per cylinder, if you have the right tools, takes about 1hr to remove cylinder, rebuild and replace.
/ Loader losing lifting ability #3
Since there are no leaks, you might need to get a gauge and check your hydraulic pressure.
/ Loader losing lifting ability #4
I'm sure by now you've checked the level of hydraulic fluid? No horrible grinding noises? Any new noises? I'm guessing seals or pump, but I'm much more of an operator than a mechanic.
/ Loader losing lifting ability #5
There is the relief valve that could be leaking as well. I would check it before the pump if you have pressure problems Dirt or sticky valve would bleed off pressure causing your symptoms
2015 Scag Turf Tiger 60in Zero Turn Commercial Mower (A64553)
2015 Scag Turf...
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
(2) RIMS FOR 10 LUG HUBS (A64278)
(2) RIMS FOR 10...
213135 (A64276)
213135 (A64276)
KMC 13 SHANK H.C. CHISEL PLOW, 3PT (A64278)
KMC 13 SHANK H.C...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
