Loader Loader losing lifting ability
/ Loader losing lifting ability #1
forest grump
The loader on my Kioti LK2054 is losing its lifting capacity, I have had the machine for about 10 years, the hour meter never worked when I bought it, at that time it had 250 hrs on it, I would guess it has about 1500 hours on it now, no sign of any leaks.
Thank for any help
/ Loader losing lifting ability #2
others, myself included, have had issues with the seals blowing out. New seals are about $25.00 per cylinder, if you have the right tools, takes about 1hr to remove cylinder, rebuild and replace.
/ Loader losing lifting ability #3
Since there are no leaks, you might need to get a gauge and check your hydraulic pressure.
/ Loader losing lifting ability #4
I'm sure by now you've checked the level of hydraulic fluid? No horrible grinding noises? Any new noises? I'm guessing seals or pump, but I'm much more of an operator than a mechanic.
/ Loader losing lifting ability #5
There is the relief valve that could be leaking as well. I would check it before the pump if you have pressure problems Dirt or sticky valve would bleed off pressure causing your symptoms
HARDEE 12' BOX BLADE ON WHEELS (A64278)
HARDEE 12' BOX...
JOHN DEERE 5075E TRACTOR (A64278)
JOHN DEERE 5075E...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2001 International 3800 School Bus (A64194)
2001 International...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2014 Ram 1500 4x4...
AKS ALASKA STRUCTURES PORTABLE TENT (A63276)
AKS ALASKA...
