loaded or not????
/ loaded or not???? #1
BLUEBONNET2
harrison county, tx (NE TEXAS)
nortrac 25 xt JD zeroturn 54", briggs mtr.
I'm brainstorming about loading my tires on a 2535 and looking at the weight of the unit, i was wondering if this really needs to been done /forums/images/graemlins/confused.gif.....r4's, fairly flat property, good drainage, etc. loader, BH, box blade
this is a fairly heavy unit compared to other in this hp range...
thanks for the input.. /forums/images/graemlins/grin.gif
/ loaded or not???? #2
BLUEBONNET2
Although it is not always necessary I think it is always a good idea to have your tires loaded when using a FEL.
Chipperman
/ loaded or not???? #3
The argument seems to be going both ways with no clear desision. I'm waiting until I feel it's worth spending money on. So far I have plenty of traction.
/ loaded or not???? #4
It makes a diference what you use your tractor for most of the time. If you use it to mow your yard you might not want the extra weight, but when you use your fel and lift anything heavy or high you should at least have something heavy on your 3pt for safety reasons. In most cases having the tires loaded is a advantage for traction and safety as the center of gravity is lower.
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2018 GMC Sierra 2500HD 4x4 Pickup Truck (A66736)
2018 GMC Sierra...
2018 PETERBILT (A68134)
2018 PETERBILT...
Bobcat SC72 (A64127)
