Load tires or not?
/ Load tires or not? #21
The Kubota manual will say DO NOT used filled tires with the backhoe. They recommend removable steel weights when the hoe is off.
/ Load tires or not? #22
Yes at least it does on the TLBs (I havent reviewed the others). However I had a an engineer on the forums with a M59 consider the extra weight vs the rear downrigger cylinder and he felt like it would easily support the added weight, AND stabilize the machine more during BH use. He was correct, it worked out great. My dealer filled the rears and didnt feel like it would affect warranty at all. I guess if I break something we will find out if that is true!
/ Load tires or not? #23
The tires on my M59 are loaded. The stabilizers handle it fine. I think it makes a big difference in stability using the loader too but I’ve never ran it without loaded tires. The tires were loaded on mine when I got it. Do you know how much weight that adds?
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A67147)
2001 FREIGHTLINER...
2003 Dodge Ram 1500 Crew Cab Pickup Truck (A64556)
2003 Dodge Ram...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2024 JOHN DEERE...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
