LK/LB confusion
/ LK/LB confusion #1
Anonymous Poster
Epic Contributor
I've been looking into Kubota, but have found a Kioti dealer nearby who I like. the Kioti model he has that would work for me (besides the ck20) is the LB1914 (20.5 gross hp). I noticed on Carver's site that they list a deal on the "LK1914" (19hp). the local dealer swears that they've made a mistake and that the smaller LK1914 does kioti doesn't exist. Can someone please shed some light here?
Also, has anyone used the 6.5 ft backhoe on the LB (lk?)? Is it a subframe mount? how has is worked?
thanks in advance!
Cheers,
/ LK/LB confusion #2
If you go to the Kioti web page , it is the LB 1914, not LK (like the 25hp and 30hp).
Mark
/ LK/LB confusion #3
As Markie said it's called an LB1914. Don't ask why! It's an ancient South Korean secret. /forums/images/graemlins/grin.gif The 1440 KIOTI backhoe is an awesome little powerhouse. Remember the tractor weighs in at around 4000 lbs with a loader and hoe on it. That and the strength of the hoe equals some very serious digging power. I believe it is one of the strongest if not THE stongest 6.5' hoe on the market. That 6.5' is to a 2ft flat bottom. It is subframe mounted and disconnects easily.
KO
/ LK/LB confusion
thanks for the info. the weight is the biggest benefit i can see to these small tractors. they seems to be at least a few hu ndred pounds heavier than the equivalent HP "big 3". is this just better construction? or is there a different approach/design that I should be familiar with?
thanks, again.
/ LK/LB confusion #5
KIOTI uses thicker castings and there is little if any use of aluminum and plastic on the tractors. The South Koreans tend to "overbuild" just about everything tractor related.
KO
/ LK/LB confusion #6
Mariner - There is nothing to dislike about the 1914. I bought one about 7 months ago with the FEL. I am coming up on 50 hours with zero complaints. Kioti uses the same engine in both the 1914 and the new CK20. The CK20 has plastic fenders. Last weekend, a large ext ladder fell and hit my fender...it only scratched the paint. I didn't think you had any flat land in Marin, just steep hills. /forums/images/graemlins/laugh.gif
/ LK/LB confusion
<font color="blue"> The CK20 has plastic fenders. </font>
The prototype I saw had metal fenders. The productions models are just beginning to hit the dealerships this week. Can anybody out there verify?
/ LK/LB confusion
<font color="red"> </font> KIOTI uses thicker castings and there is little if any use of aluminum and plastic on the tractors. The South Koreans tend to "overbuild" just about everything tractor related.
As someone who lived in Korea for 2 years I can tell ya that wood, paper, plastics and aluminum are extremely hard to come by and expensive. Metals, except brass are easily found there and within there neighboring countries. Which is good for us Korean tractor buyers. Also Daedong is a household name like Johnny D. I would almost bet ya the farm it's been around twice as long as JD.
Good day, Dewave /forums/images/graemlins/smile.gif
/ LK/LB confusion
I believe the ck20 I saw had metal fenders. I wasn't aware that there are prototypes out there, but the salesman said that he had the first tractors off the boat, since we're close to the port of entry. at least that is how it was presented to me. I was a little confused because I saw both HST and geared versions of the ck20 and had thought that these were all going to be HST tractors. Also, I thought that it was designed as a TLB, but found that they don't even have a backhoe out there for it yet. I was told that there's one in the works, but not yet available. can anyone confirm?
my biggest concern about the CK20 is that it's a new model that appears to be a complete departure from the 1914 (I didn't know that it is the same engine, so that makes me feel somewhat more secure). Otherwise, it's just about what I'm after, assuming I can get a good backhoe on it. If not, I'd be inclined to go without HST in return for a proven backhoe on the lb 1914.
/ LK/LB confusion
It was reported here that the CK20 will use the same backhoe as the 1914.
<font color="blue"> If you have a dealer close by, see if they have a LB1914 with a loader and Hoe. If you like the way the hoe operates on the 1914, you'll like it on a CK20. They will be the same hoe. The CK WILL have more loader lift and will be the radius arm style but the hoe will be the same you see on a 1914. The CK is only around 135 lbs lighter than the 1914. We have sold quite a few of them, even with the extra heft of the tractor with loaded tires, the hoe can pick up the tractor and move it!
Kiohio
</font>
/ LK/LB confusion #12
Fenders
I have not seen a CK20 in the flesh. The plastic fender claim came from my dealer over 6 months ago. That may have just been a rumor from last summer. /forums/images/graemlins/crazy.gif
/ LK/LB confusion
Re: Fenders
My local Kioti dealer said that the soon-to-be-available backhoe for the CK is the KB2365 whereas the model for the LB 1914 is the KB 1440. This might be just a sub-frame difference, but Carver lists the KB2365 as a 6 ft. hoe and the KB1440 at 6.5 ft. (and roughly $400 more). Could the differences be explained by the tractor ground clearance?? If not, sounds a lot like a different hoe.
/ LK/LB confusion #14
Re: Fenders
Here's what I learned about kioti backhoes during the buying process. The kb1440 is/was made by a company here called smc. Kioti has decided to make their own which is called the kb2365. The 1440 is is basically out of stock and no longer made for Kioti. The 2365 looks basically the same but where the hydrualic hoses attach to the hyd-cylinders is "wimpy". They have little elbows welded on to the cylinder where the 1440 has larger blocks welded on. I think a small branch could knock off one of these elbows. I have seen both. The dealer I am in the process of buying from has opted to get the backhoe from the manufacturer of the 1440 until kioti improves the hydrualic connections. Also, the 2365 I saw didn't have covered hoses like the 1440 does. Hope this helps. By the way, My 1914 w/kl1210 and 65a bh is due to be delivered 6/21/03 Yea!
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2014 Chevrolet Silverado 3500 Crew Cab Utility Flatbed Truck (A60352)
2014 Chevrolet...
159115 (A60430)
159115 (A60430)
24220 (A56859)
24220 (A56859)
Triple Sink Table (A60352)
Triple Sink Table...
