Backhoe LITW backhoe on T273
/ LITW backhoe on T273 #22
Hello Flyer91,
I am looking at purchasing a tractor and the TYM273 sounds great.. How is it holding up. I live in Northern California near Grass Valley. I have sloping land and I am thinking of getting the TYM T330HST or the T400 with FEL and BH. I have located a dealer in Los Molinos, Lane Tractor Sales. I have been qouted $22,000 for the 330 and $25,000 for the 400 that is including the FEL and BH. I have never owed a tractor and I am not sure how the TYM's hold up compared to Kubota, Kioti, JD, ect.. I like the pics of tractor in action. Look forward to reading an update from you.
WJ
Well, it's getting near 3 years with this T273/LITW backhoe and it is still broken (blowing O-rings as fast as I replace them).
I've had about 50 hours of running from it and @ ~$4k for the hoe, at best that's $80/hr until it became a boat anchor.
Steve at Valley View has offered me a few options, but all mean throwing significantly more good money after bad, because at this point we don't know if it's the backhoe or an issue with the T273.
So I'm giving up on it and going to let it leak and use it only if I need it for emergencies.
If you are thinking of buying an LITW backhoe, I would advise you to think again.
This thing is a POS, and it's warranty is useless!!
To be honest, had I to do it over again I would have bought JD, and had local service.
In my experience, this TYM/LITW is just a "use a few times and throw" away product.
/ LITW backhoe on T273 #24
The backhoe should have its own pressure relief valve.
Sounds like your problems are all with the backhoe and not the tractor.
I'm on the 3'rd one.
The original, a replacement, and the one that came with the second control block.
The current thought is that there is possibly some obstruction in the TYM's return.
I've checked the check valve and the QD, they are both working fine and with no debris in them.
when I replaced the valve block it was a total replacement with all the spools, control levers and etc, and as indicated the O-rings just keep blowing.
I am tired of working on it, and am very disappointed that the only help I got was from the dealer alone.
No LITW help, nor TYM help whatsoever.
When I tried to contact the valve mfg they told me they will not talk to me about it, and I have to go to the dealer ..... who has (IMO) gone beyond the call of duty, but in the end needs more money to help me get a piece of equipment (that hasn't worked right from about 40 hours from new) fixed or replaced.
But not knowing exactlty were the problem is, has me either looking at taking a chance on a replacement hoe of any make, or throwing another ~$800 to get a pump and tank, then hope the problem is in the tractor or I'm still chasing a goose.
Not a very good bet in view of what has already been done to try and fix it.
So ....... it just sits in my equipment shed, looking the part.
/ LITW backhoe on T273 #26
Can't your dealer allow you to test a TYM hoe? Mine has never leaked or acted up in any way north of 100hours and some serious digging. Seems it would help with process of elimination.
Actually Steve at Valley view has graciously offered to replace the hoe, or allow full credit towards a TYM hoe, or provide a pump and tank at cost.
The problem is that since the LITW hoe has had O-rings replaced, then it's entire valve block replaced, then more O-rings replaced after verifying the return line is not obstructed, there is some uncertainty to exactly what/where the issue is/lies (hoe or TYM).
I'm in central California and shipping the hoe back to Oregon, then shipping for a replacement back to me again, is too costly in view of not knowing if the tractor has some issue (blockage in it's hydraulics) and spending the money for a pump and tank to bypass any problem the TYM might have, is also too costly a gamble in view of this unknown.
I'm retired and am totally past my patience, but more importantly ..... my abilities/tools to further troubleshoot and take this thing apart and rebuild it again ...... all to no avail.
The real problem here is that there is no local service for either the hoe or tractor, and I'm just not willing to throw any more money or time at it.
Unfortunately a 1 year warranty and a 5 year (LITW and TYM respectively) are meaningless if you do not live within driving distance of a dealer, or it only provides a "do it yourself" approach to repairs, with more out of pocket for shipping, which ultimately ends up (in my case) with me having to further spend the additional best part of a $1000 (or more) with no certainty that will fix the problem.
No one from LITW or TYM was being sneaky here, it's all in the warranty. I was just hoping for more from them than to just leave it on me and Steve.
Apparently LITW and TYM don't provide any more than "go fish" in these circumstances.
The lost time is not of concern to me because I'm retired, but if I was needing the TLB to actually work for more then the 40 hours
(basically a single week of use) after purchasing it, I'd be up a creek that a JD purchase would simply not have had me boating down without a paddle and no sign of a port.
So ...... my caution is to walk away 'far away' from any LITW choice, and only opt for a TYM hoe for a TYM tractor.
If you don't have local support for a TYM, think long and hard about going that way too.
You could very well end up being me. Holding two pieces of paper that are useless warranties (too crispy for even remedial use) and a broken POS TLB.
/ LITW backhoe on T273 #28
Rent a trailer? I wouldn't blame whatever you aren't sure of either. If you know that's a different story.
FWIW, there are others here using non-TYM hoes.
/ LITW backhoe on T273 #29
To prove the tractor you can easily place a test gauge to the pressure line to the hoe to read the tractor, If the pressure is to high the relief valve can be adjusted. Im sure its fine, Id suggest that you upgrade to TYM's backhoe
/ LITW backhoe on T273 #30
I'd second the "TYM Backhoe" idea. If the dealer is offering, take him up on it. I understand the hesitation to throw more money at it however you really don't have many options. I have a difficult time believing the problem is with the tractor.
I'm reading about the issues that another 273 owner is having with a TYM hoe, and others that are having similar issues with the rear remotes, and I'm wondering if my issue might be of a similar root problem.
Seems like TYM has a "sometimes-fix" that doesn't instill a lot of confidence in their design/quality of workmanship ...... swap the lines. (???)
As I've indicated in this LITW saga, I have replaced relief valves, rebuilt the spools, and replaced the entire LITW valve block with it's spools and control levers intact as a complete unit, and I just keep blowing the o-rings in the LITW.
I'll swap the lines and try putting the remote's control lever in the opposite position.
If this voids my warranty, I guess that's not big deal.
Heck ...... in my case it's proven to be pretty much worthless anyway. ;-)
I can certainly understand why my dealer is offering a "just bypass the TYM altogether" option of a PTO pump and tank.
If I don't get some permanent fix I guess I will do that as it is probably a smart move if only to avoid any possibility of somthing in the hoe contaminating the oil and taking out the HST, etc.
/ LITW backhoe on T273 #32
BEG your local to you dealer to try out the hoe for you- pay him-. He can hook your hoe up to another brand of tractor and see what the deal is. This will eliminate the tractor or hoe as culprit.
My local dealers even though they didn't sell me my machine are very acceptable to some swaps for cash. They all seem to enjoy the cash. I'd even try a place where they rent tractors rent one and try it yourself. Half day rental should suffice?
Bout all I can think of......
If you are saying TYM is responsible for dealers hooking up hydraulic lines backwards, please. It's a fifty -fifty deal. Switching them takes- what a minute.
Your dealer is responsible for final inspections and checking everything over. Adjusting the pedals and what not...
I have honestly and literally taken stone walls a part with my machine and dug holes for septic, ditches for drainage, stumped, rocks in peoples yards, not one leak or breakage.
Also have you changed the fluids in the machine yet and HST filter? It's pretty easy , messy, but easy.
/ LITW backhoe on T273 #33
Sorry to hear of your ongoing problems with the LITW hoe, FLYER. That
is supposed to be well-made Korean unit.
If I had your setup, here is what I would try. First, I would plumb the
hoe return line straight to the sump. It would require a new QD fitting.
This will greatly reduce the back-pressure you are getting by returning
the hoe's fluid thru the restrictive AUX valve. Powering the hoe thru
the AUX valve is not the best setup, in my experience. My current
main tractor uses the AUX valve for the hoe, and its restriction does
cause significant oil heating if I use the hoe for more than 15 min
or so.
The best solution would be to plumb the hoe thru a power beyond port
of your FEL or AUX valve, with the return going straight to the sump.
Thanks dfkrug!
I'll see what it takes to connect a direct line to the sump and bypass the remote's valve.
This should at least let me know where the issue lies, and is probably the best way to set it up seeing as I don't need to reverse the rear remote's flow for any of my work.
Berst regards,
Gary
/ LITW backhoe on T273 #36
We sell a Korean Curved boom backhoe by Ansung a high quality unit.I'm betting that the problem is in the hydraulic plumbing from the tractor and the backhoe is getting the blame.I sold LITW for a while until I found the Ansungs and they are a good backhoe.I would bet if you isolate the hydraulics by going to a Pump and tank your problems will be over,something in the TYM 's aux, hydraulics is causing the system to dead head which in turn is blowing out the o-rings.Spend the money get the Pump & Tank combo.We do not plumb any of our backhoes off the Aux. valves, we tie into the hydraulic system or use the pump/tank kits
Tommy
Affordable Tractor Sales
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
