Liquid Ballast
   / Liquid Ballast #1
skent
Platinum Member
Westminster, Maryland
Kubota B7300
I am planning on adding liquid ballast to my rears (31 X 15.5 - 15). Was planning on using 'used' antifreeze or else RV antifreeze. Would need around 17 gallons each to get 75% fill. I would like to use beet juice, but have not been able to find it around here.
I had thought it would be wise to install inner tubes prior to loading the tires, in order to save the rims and have a second barrier.
Are there any pro's or con's to this? Should I load them with tubes, or keep them tubeless?
Thanks.
Steve
   / Liquid Ballast #2
I have done it both ways and the only advice I can give is this. Tubes are harder (takes longer and more aggrivating) to fill and harder to remove (empty).
   / Liquid Ballast #3
I have calcuim in my tires and it is hard on the metal parts. That's the way it came when I bought it. If I had my choice, I'd tube the tires and run windshield washer fluid or the beet juice.
<font color=green> MossRoad </font color=green>
   / Liquid Ballast #4
Steve,
I've got washer fluid, no tubes. Thought about RV antifreeze but washer fluid was cheaper. Used antifreeze should work great if the price is right (free).
Good luck,
Michael
   / Liquid Ballast #5
When I purchased my new Kubota the dealer told me whenever they sell a tractor with a FEL they always tube and fill the rear tires with calcium. I suggested antifreeze but they said it didn't have the same weight as calcium. I have a 1952 Ford 8N with loaded read tires, about 14 years ago I replaced the rear tires had new tubes installed and filled with calcium. The rims are over 20 years old and still holding air/liquid.
Unless you have the equipment you will have to have the work performed by some one who does, the extra work installing tubes is only a little more labor charge and the price of the tube. If it were me I would have tubes installed.
Randy
   / Liquid Ballast
The reason I'm asking is the place where I'm going to get the tubes said its better for the rims if they are in full contact with the solution (filled to cover the top of the rim) with no tube. In this fashion, the metal rims never see air and therefore never rust (?). He recommends Magnisum Chloride as it is less corrosive than Calicum (? again) or RV antifreeze. He never heard of rim guard.
I'm not sure if I believe that or not.
He continued to say if you have the calicum (or other liquid) in tubes, the small nooks and crevices between the filled tube and rim will have air gaps and will lead to condensation, and trapped water between the tube and rim and the fact that its not submerged ALL THE TIME will lead to rust.
I have the equipment for filling and draining tires. (picked it up cheap at an auction)
I have two Case (195X) ag tractors, both with calicum filled rears with tubes. One problem I had was many years ago the SC's left tube had a VERY TINY pinhole leak that was so small it went un-noticed for years eventually rusted out the rim. Quite a job finging a 38" rim for a 50 year old tractor. The other problem is the valve cores only last 2 or 3 years using calicum. I now replace the valve core's on those every year.
I don't want that happening to my Kubota.
Thanks for all the replies.
Steve
   / Liquid Ballast #7
I think the weight difference will be minimal between calcium and windshield washer solution. If you have any doubts, weigh a gallon of each.
   / Liquid Ballast #8
Skent,
If I were loading my rear tires with used antifreeze, I wouldn't worry about putting tubes in the tires. It's my understanding that antifreeze contains additives that prevent corrosion because it is in contact with metal all the time. The added aggravation of tubes would not be warranted, in my opinion.
That said, it is just my opinion. I'm likely going to load my rear tires with washer fluid or non-toxic antifreeze. If anyone knows of a rim failure due to use of washer fluid or antifreeze and no tube, please speak up!
   / Liquid Ballast #9
I have calcium chloride in tubes and would do the same again if I were to do it over. Unlike others, I dont worry about possible corrosion.
However, filling tires is an area where I have changed my mind. I wouldnt do it over again, and am thinking of draining next spring. In my particular soil situation and for my non-agricultural, non-contractor uses, the enhanced traction and stability provided by tire ballast are unnecessary. I would rather have lighter weight for my grass and soft soil areas. The only place I think the tire ballast may have improved things is traction in snow--but I cant really be sure of that because I havent been in snow without filled tires.
I think I have entered a new, down-with-big-heavy-honker-equipment stage of my evolving and ever-erroneous tractor philosophy. Seven mud burials can do that to a man.
   / Liquid Ballast #10
I thought there was a difference of around 3 pounds per gallon - between calcium chloride sol. and windshield washer fluid. 11+ pounds vs. 8 pounds. Anyone have those figures?
   / Liquid Ballast #11
Hi Steve,
I can't speak from first hand experience here but my dealer said the same thing as your's. Said he'd seen more damaged rims caused by condensation between the tube and rim and small leaks than by having calcium solution in direct contact. My tires are filled with windshield washer fluid which is not corrosive and won't contaminate or kill the soil if I ever get a leak or blowout. But it's not as heavy as calcium solutions can be or antifreeze (I believe?). That works out well for me though because I don't really need/want more weight when I'm mowing the yard.
Dave
   / Liquid Ballast #12
So in his case, the tires would weigh about 50 pounds more each with calcium, correct?
   / Liquid Ballast #13
Just a quick question, why not use something like sand or other heavy dry subtance for weight?
TC33D
   / Liquid Ballast #14
Yes, MossRoad, about 50 pounds for the 17 gallons 'skent' was working with for his tires.
MikeBurr - don't know for sure why, but suspect if dry (sand) would work, we would see it being used. I would think there would be tremendous internal tire wear from sand. Someone not too long ago posted he thought that lead was used a long time (?) ago, but I don't hear of anything like that anymore. If the tire gets going at road speed, I would imagine dry fill would start to roll over the top, and cause some wild girations to the stability of the tractor - as can happen with fluid in the tire if the tractor is allowed to get a lot of speed, like coasting down a long steep hill (have heard that happening to farm tractors with disastrous results). Still, I used to enjoy puttin her in neutral and letting her roll down hill. Had to let it come to a stop to get the thing back into a gear, which took some (most!) of the fun out of it.
   / Liquid Ballast #15
beenthere
You might be referring to my post/w3tcompact/icons/wink.gif. A B7100 w/ all 4 tires loaded w/ #8 high antimony shot and some kind of slippery stuff my dad concocted. It's been in there since approx. 1990, no handling problems and no adverse effects observed yet. Don't recall even adding air to 'em. New tractor has all 4 loaded w/ Rimguard. Note:eek:wners manual says not to load the front wheels, but I'll stick w/ it.
regards
Mutt
   / Liquid Ballast #17
Just a couple of watch-out-fors that haven't yet been mentioned in this thread:
New/used anti-freeze can be an environmental hazard if you spring a leak. Animals are attracted to the stuff and can die with after ingesting fairly small amounts.
RV anti-freeze will kill your grass if spilled/leaked. I know this first-hand as I have managed to spill some each of the last two years winterizing our camper. It works better than Round-Up!
I've been toying with the idea of Rimguard myself. I understand one of our local Farm Bureau Co-ops fills tires with it. You might check your co-ops /w3tcompact/icons/smile.gif
   / Liquid Ballast #18
Roughly how much weight does one gain with liquid-filled tires? I have a 4300 with R4s, and might need to go with chains or weight this winter. Haven't had a chance to see how it is for snow pushing yet. How much do they charge to fill the tires?
Thanks,
Bob
Bob Trevithick
   / Liquid Ballast #19
Bob - I beleive the 4300 has the 15.9 x 19 Titans, the same as my 790, I filled the tires on mine early fall, added 5 gallons of methanol and about 28 gallons of water each. This adds up to about 260 pounds per tire. This was to just over the valve stem. Have to park with the valve stem uphill to check the air pressure. I did it myself, purchased the methanol from local farm equipment fix-it shop for $4 per gallon, and the adapter to hook a garden hose to the valve stem for $14 at NAPA, already had a small drill operated pump. Put the methanol in first and added water. Did it by pumping it from 5 gallon buckets to be sure I didn't exceed the 6 to 1 ratio recommended to give good freeze protection. Hope this helps.
   / Liquid Ballast #20
Well, according to the last few messages, about 8 to 11 pounds per gallon, depending on choice of liquid. The tractor I have weighs about 1500 pounds more than the advertised weight. I can only assume it is because of the weight of the cab and the liquid in the tires. I can't recall off hand the size of my tires, but they come up to my armpits, so I'll guess at about 54".
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
UNUSED IRANCH MINI EXCAVATOR RAKE (A60432)
UNUSED IRANCH MINI...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
