Liquid ballast in tractor tires.
/ Liquid ballast in tractor tires. #1
patrickg
South Central Oklahoma
Kubota Grand L4610HSTC
For some reason known to the Kubota engineers but not to me, there is a warning in the Kubota Operator's Manual for the L series including the L3010, L3410, L3710, L4310, and L4610 where it says:
IMPORTANT
* Do not fill tires with water or solution more than 75% of full capacity (I understand this part, read on)
* Do not fill tires with water or solution if the tractor is a CAB model. (<----- that is the one!!!)
Anyone know the problem? Anyone care to speculate? Why should they prohibit liquid ballast for the model with a cab???
Patrick
/ Liquid ballast in tractor tires. #2
It would appear that they're trying to limit the total weight to protect the tires. I certainly don't think they're worried about the additional weight on the rims or axles.
MarkC
/ Liquid ballast in tractor tires. #3
Mark,
WAG /w3tcompact/icons/smile.gif Maybe the cab model will not support the added weight of loaded tires in a roll over.
Al
/ Liquid ballast in tractor tires. #4
Al - More like a SWAG than a WAG, if you ask me. Definitely a possibility...
MarkC
/ Liquid ballast in tractor tires. #5
What's the S in WAG stand for?
Never mind, I remember.
<font color=green> MossRoad </font color=green>
<P ID="edit"><FONT SIZE=-1>Edited by MossRoad on 12/27/01 03:52 PM (server time).</FONT></P>
WAG, SWAG, OUIJA board, or bird droppings interpreted by the oracle of Delphi... The most interesting guess so far is the strength of the cab in a rollover. I'll find out eventually what the Kubota engineers had in mind and report back so we can all have a laugh or become better informed and safer citizens.
Patrick
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2018 Toro Workman HDX Diesel Utility Cart (A59228)
2018 Toro Workman...
