Linear Actuator
/ Linear Actuator #22
Here's a picture of mine
/ Linear Actuator
I like the way you set it up, how many force pounds is the actuator?
The top mount is it curved or straight like the bottom mount?
/ Linear Actuator #24
Here are the pictures originally provided to me by Paul? Repair Specialties
I have obviously adapted to fit my application but you will get the main plans
/ Linear Actuator #25
mine uses a small hydraulic cyllinder on the deflector, but i have no idea how much force is beilg applied to it from the snow while its blowing. Considering the tonnage of snow blown out the thing, it could be quite alot. They have a pretty beefy cyllinder on mine.
Your chute is a lot different than mine. Mine is two pieces.
/ Linear Actuator
Great pictures and measurements, they helped alot.
Now I have to decide which way to set it up, on the side or on top.
Been doing some measurements and either wat I need a 4"stroke.
Have to decide on the force pounds also. I can get a 35 pound push/pull actuator with a 200 pound static force but it is a high speed unit or I can get a 150 pound push/pull with a 522 pound static sorce, which is a slower speed.
I am leaning towards the normal speed because of the high static force with a heavy wet snow in mind.
High Speed:
Linear Actuators
Normal Speed:
Linear Actuators
/ Linear Actuator #27
Msb1776;
Have you decided what mounting method you will use for the actuator or what type you will use?
Something to consider; I mounted an electric power window switch on the tractors joystick so that I would have all snow blower functions available in one place and not have to reach and take my hand off the controls
/ Linear Actuator
I am going to mount it similar to the way you mounted yours.
I ordered a 12 volt 150 pound thust push/pull actuaor with a 4 inch stroke.
I also ordered a rubber boot cover for the actuator.
The actuator should be here by Wendsday. I ordered it last Wendsday.
I have been building the brackets and have it all wired.
I bought a momentary return to center toggle switch and put it in a plastic box. Right now I have just tie wraped it to the loader control lever. Will mount the switch box better when I get it all figured out.
Linear Actuators
Linear Actuators
DPDT 20-Amp Momentary Flip Switch - RadioShack.com
/ Linear Actuator
I got the actuator all put together and wired here are some pictures of the actuator and control box. I mounted the control box on the loader lever, by cutting a 3/4" nut enough to fit over the lever and tapped a small bolt into the side of the nut to secure it to the lever then welded a piece of round bar to the nut and to a piece of flat steel, wrapped some tape around the lever to protect the lever paint.
/ Linear Actuator #30
That looks like a very nice job.:thumbsup: I think I'd have put the box on the outside of the joystick so that I didn't hit it with my knee, but if it works for you where it is, that's fine. . . just a case of personal preference.
/ Linear Actuator #31
Msb1776;
That works, looks good!
Did u remember to loosen the bolts that allow the chute to pivot?
/ Linear Actuator
Yes I did loosen them. Will try to get a video of it moving so you guys can see the speed.
/ Linear Actuator #33
I've used Linear Actuators on three blower chute deflectors and they work great. I always got one hand in the shop. For the chute rotator you can use a power window motor. Lots of power in those as well.
/ Linear Actuator #34
Hope this helpsView attachment 239448
:laughing: I forgot about them. I made the same brackets for my buddy's chutes and mounted the linier actuators between them.
/ Linear Actuator
When I bought the blower I also got the optional hydraulic chute rotation.
I can move the control box if I need to, just loosen the set screw. It felt good where I have it but that was when I was in the garage so we will see how it fells when I am actually using the blower.
/ Linear Actuator
Here is a video of the actuator:
[ame=http://www.youtube.com/watch?v=aaKW7-iXPRc]M2U00119 - YouTube[/ame]
/ Linear Actuator #39
msb1776;
Looks good!
Only 1 point of interest!
I did the same thing and mounted with "cylinder". Up like a hydraulic cylinder.
If you flip it; will prevent moisture from entering the inner workings
/ Linear Actuator
The actuator shaft does have an O-ring in the housing but I don't know how
well it protects the motor.
I thought about that but if I flip it the screws that hold iy together will be up
and i was afraid that water would get in that way. I was thinking about getting a cover for the shaft, something like a shock absober boot.
Like this:Buy Monroe Magnum Steering Stabilizer (Single Kit) SA1997 at Advance Auto Parts
2019 Terra Gator TG8400C Spreader (A63111)
2019 Terra Gator...
YALE FORKLIFT (A63291)
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
Geringhoff Adapter (A63117)
Geringhoff Adapter...
GRAVITY WAGON (A63291)
