Linear Actuator
/ Linear Actuator #2
The only thoughts I have is for you to turn the chute by hand and use a guess as to how many pounds of thrust you think it needs. What you also need to consider is how many degrees of rotation you require for the chute. There will be some angular vector forces to take into account.
I think your 115 LBS thrust is a good starting point, and stroke is the another consideration ?
Craig Clayton
/ Linear Actuator #3
Northern tool sells one that's a little more money but I think would work much better. It's designed to dump garden tractor carts. That one you listed may work but I would want to know if it was weather tight. Plus it sounds like it has an aluminum rod. Moving the chute isn't too hard but it needs to hold the chute where you want it. I'm not sure if aluminum will handle it or bend (would need to know the diameter of the rod).
Wel-Bilt Linear Actuator — 12 Volt, 11 13/16in. stroke | Lawn + Garden Utility Trailers | Northern Tool + Equipment
/ Linear Actuator #4
Craig Clayton
He's talking about the chute deflector, not the chute rotator.
/ Linear Actuator #6
mine uses a small hydraulic cyllinder on the deflector, but i have no idea how much force is beilg applied to it from the snow while its blowing. Considering the tonnage of snow blown out the thing, it could be quite alot. They have a pretty beefy cyllinder on mine.
/ Linear Actuator #8
I incorrectly in my read the orginal posters question. So I looked at the last posters picture of his chute deflectors hydraulic cylinder. So if we were to guess at a 30 LBS thrust at the tip of the chute and the chute is 9 " from the pivot point. The cylinders pivot point might be 3 " from its pivot point . This would create a 3 times mechaincal load on the actuator. So in guessing the actuator might have to push a 30 X 3 = 90 LBS thrust. ( more or less )
Craig Clayton
/ Linear Actuator #9
Also there is a big difference in power needs depending on whether you activate before you blow or while blowing. At idle very little power would be needed.
/ Linear Actuator #10
If you are looking to build your own, check out an old 6 foot satallite dish actuator. Most are outdated and people will give them to you just to remove it. It will run on 12-36 volt and the rod can be cut off as short as needed. As for force leverage will make up if there is any shortfall in power.
Russell
/ Linear Actuator
ericher69, I like the mini actuator do you have any pictures that you can post or email me of the way it is set up on your blower?
Can you move your deflector up and down while blowing snow?
/ Linear Actuator #15
Ok,
No PM's
Kubota wanted like $800 installed for a hydraulic chute deflector!
I said; don't think so
Got er done for about $120
/ Linear Actuator #16
Thank you for the info, and yes, we are eagerly awaiting those pictures.
I gotta ask though, what is the lowest temps that you used it in? Specs say it is rated to -15F
/ Linear Actuator #17
-30C
About -22F
The only issue I have had is the threads stripping from the end of cylinder
I drilled and put a bolt thru...good 2 go
4th season in use!
/ Linear Actuator #18
-30C
About -22F
The only issue I have had is the threads stripping from the end of cylinderI drilled and put a bolt thru...good 2 go
4th season in use!
Now I'm confused, the actuator you referenced in your link doesn't show threads, it shows a 'clevis style' hookup.
Could you possibly show this when you post pics?
/ Linear Actuator #19
Clevis hook up
Cylinder rod is female thread/Clevis end is male thread
Linear actuators tend to want to rotate when ext/retracting
Hydraulic cylinders are not affected by this as fluid pressure is distributed evenly on rod end
For myself and approx 1/8 the price it's definitely worth anything short of perfection
/ Linear Actuator #20
Clevis hook up
That explains it. Thank you.
Sounds like a job for red locktite.:thumbsup:
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
10' Dozer Blade (A64119)
10' Dozer Blade...
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
CLARK WAREHOUSE FORKLIFT (A63291)
CLARK WAREHOUSE...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
