Lincoln Arc 225
/ Lincoln Arc 225 #21
Please follow up with a review after you've used it a bit. Pictures included of course!!!
I've got a Lincoln AC/DC 225 that I leave in the machine shed at the farm. Serves me well. But always interested in improvements. :)
/ Lincoln Arc 225 #23
You might try some 1/8 7014 also. It is extremely easy to start and run. Some consider it a "drag rod". It just about runs itself. On your 7018 (my favorite rod) they strike easy the first time but when you break the arc a "corn" of glassified slag forms on the end of the rod making it difficult to re-strike the rod. I break it off with my gloved thumb before attempting to re-strike the rod. Others file it off etc. But you will have to remove it one way or the other before the rod can be restruck. Some just use a "peck peck" motion to get it off.
/ Lincoln Arc 225 #24
If you could get some ESAB 10P-Plus 6010, and ESAB Atom Arc Acclaim 7018.
Your local Air Gas should have them in stock.
This is about all I use and I can weld any type of steel with it even cast iron can sometimes be welded with 7018 if it is a thick section. I only stock 3/32" and 1/8". Most of my work I do with 3/32 if the work piece is 1/4" thick or less. Thicker than 1/4" I may break out the 1/8" if I am going to put a large amount of weld metal down. I like the 3/32 because it doesn't excessively heat up the weldment.
My 6010 is 1/8". I do have some (1# bags) 3/32" 6010 for the really light weight stuff.
/ Lincoln Arc 225 #25
7014 is childs play to run. Last picture is vertical up hill.
/ Lincoln Arc 225 #26
If you want to look at this you-tube by Jody at welding tips and tricks. If you want to see 7014 welding by itself start at 7:30 minutes
You should subscribe and watch every video Jody has made. You could have a lot worse instructor than Jody.
/ Lincoln Arc 225
He made a comment about the 7018, needs to be in a rod oven or used once opened. That could be an issue, since I don't have a rod oven nor will I weld enough to use a lot of them.
/ Lincoln Arc 225 #28
It needs to be in a rod oven ONLY if you are making x-ray welds. Don't let the rod oven scare you. I don't have one either. And the welds I have made I use all the time with 7018. Aint any of them broken yet. Just normal storage in a rod container will suffice for guys like you and me. Heck Shield arc can tell tales about using 7018 from a bucket full of rain water.:) Here is a hook welded on the Kioti with 7018 at 125 amps with my little Everlast Pa160
/ Lincoln Arc 225 #29
Unless you are doing code welding, don't worry about a rod oven. Just keep them dry. Maybe inside the house.
/ Lincoln Arc 225 #30
I get along pretty good in my shop because the humidity is relatively low, especially in the Winter with a wood stove going. At the farm it's stored in an uninsulated/unheated metal machine shed. It doesn't like that nearly as well. So I just keep a limited supply there. :(
/ Lincoln Arc 225 #31
The rod oven is to keep 7018 dry which it is a Low Hydrogen rod, and if moisture gets in the flux it can form hydrogen gas bubbles in the weld bead from breaking down the water molecule. And while I am sure a nice hot fresh 7018 just out of the oven would be ideal, I have gotten by just fine with just keeping them in a rod holder with a sealed gasket. Harbor Freight has holders at reasonable prices as does others.
/ Lincoln Arc 225
Great information guys, this is why I have grow to love this forum. Great knowledge from tractors to many other areas that life throws our way.
/ Lincoln Arc 225 #33
Living in the North West, I can't tell you how much bridge, and overpass falsework I've built in the pouring down rain without a tent.
This is how we used wet 7018.
/ Lincoln Arc 225
Does it matter where I get my rods? Example, welding shop or Harbor Freight? 7018 1/8" rods.
/ Lincoln Arc 225 #35
Shield Arc,
In the first picture middle row, I notice that there are no BB's at the left and a noticable number at the right and I can't figure out what caused it. Can you enlighten me, please?
/ Lincoln Arc 225 #36
Others may differ, but I haven't had much luck with Harbor freight rods. I have had good luck with Hobart, Lincoln and US Forge rods.
/ Lincoln Arc 225 #37
Shield Arc,
Only thing I can think of is, the rod got so hot at that point the flux was coming off the rod. Cause the weld went ape **** on me. :eek:
/ Lincoln Arc 225 #38
Carl - - you GOT the T shirt, right?
Terry
/ Lincoln Arc 225 #39
No I don't, but I worked with several guys who would have worn that shirt with pride!:laughing::laughing::laughing::thumbsup:
/ Lincoln Arc 225
Just picked up some rods. Looked at E6011, E6013, and E7018 all were 1/8" rods. I grab a 5lb box of E6011, the little chart said it would work on old rusty metal. I will be grinding to clean metal where I am welding, but figure this would be a good starting point.
Thursday! PowerArc 200ST should be here Thursday! I'll take pictures and post.
7002SFL (A61572)
7002SFL (A61572)
HURRICANE (10) DRAWER (A64280)
HURRICANE (10)...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
UNUSED AGT SSECAG-Y (A64281)
UNUSED AGT...
HONDA WP40X 3" WATER PUMP (A64281)
HONDA WP40X 3"...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
