Lifting safe - Ballast Box needed?
/ Lifting safe - Ballast Box needed? #22
If you don't have good pallet forks, might see if you could rent one for a day somewhere.
/ Lifting safe - Ballast Box needed? #23
OP hasn't been back to read any of these replies. Maybe soon?
Thanks to all for the reply’s. I do have forks which will be used. I also forgot to mention the rear tires have fluid in them. For the lift I’ll attach a rotary cutter to the 3ph. As suggested, I’ll lift and have truck drive out from under.
Hooked up rotary cutter this afternoon and almost took out electrical box while backing up. After lift I’m going to get or fabricate a ballast box.
Again, many thanks for the guidance.
Jim
/ Lifting safe - Ballast Box needed? #25
Suggest not backing away unless perfectly straight away until the load is near the ground
If ballast/balance are in doubt, this is important, if it's a 2WD tractor, it will spin before being a hazard going backward. But if you're in 4WD and back up too quickly, that can tip the balance. I like the idea you're going to use ballast. As I get old, I find myself pausing and thinking a lot more than when I was young. I think to myself: Will it be quicker to do it safely noe, than to fix it after I get back form hospital later? So I stop and do it the most safe way I can think....
/ Lifting safe - Ballast Box needed? #28
But that's what I told my wife!
😆 "Honey, I need some tractor ballast and it's going to cost $5,000!"
I would want ballast for that much weight. Hook up an implement or get the ballast box if you don't have implements. A much cheaper solution is a used dirt scoop that can be had for usually less than $200 on craigslist or FB Marketplace. Fill it with dirt, bricks or throw in a few bags of playground sand. You can then use it for other things besides just ballast. They are also very compact/narrow.
/ Lifting safe - Ballast Box needed? #29
I am interested in how the unloading went? I took my trailer to the store where I bought my safe and they loaded it, then I came home and used my tractor to unload it. Nothing to it!
David from jax
/ Lifting safe - Ballast Box needed? #30
With a backhoe on you wouldn't need a counterweight???:unsure: Then you would have something more usefull than a counter weight?
:unsure:
True...but a backhoe is mighty expensive ballast.
I've had a backhoe...never had much need for one, but it came with the Deere 4520 I bought (I wanted the tractor for the cab, not the 'hoe).
Frankly, unless one has a need for a 'hoe, it's a waste of money
/ Lifting safe - Ballast Box needed? #31
David from jax
On friday he said its being delivered "next week".
So I assume the unloading hasnt happened yet. But I too and curious for the update when it does happen.
/ Lifting safe - Ballast Box needed? #32
The one benefit of a back hoe as ballast is that if you really get yourself mired in, you can grab a bucket load, and stretch it way out, then the front end gets really light, while you try to wiggle yourself out of the mess you drove yourself into . But, on the whole, I agree, for compact tractors, I'm not a back hoe fan, I find the separate excavator much more useful. By having two machines, when you get one stuck, you have the other to get it out with (or get stuck too!)
/ Lifting safe - Ballast Box needed? #33
Correct, however my Backhoe can lift and swing to side and move my 8,000 tlb tractor, So I have used the excavator for rescue only a few times.
There is 2WD stuck, 4wd stuck, 4WD TLB and come-along stuck, then there is excavator stuck. Yuck, that's a mess!
/ Lifting safe - Ballast Box needed? #34
/ Lifting safe - Ballast Box needed? #37
I'm thinking when I build a ballast box I'd like to make the mounting extendable so that the box can be tucked in tight (where I see most ballast boxes) or hung out at least a couple feet farther out the back.
The more distance it's got, the longer its lever arm and the more effective it is as a counterweight.
As it is, my light duty rotary cutter (RCR1260 - 5'), which according to specs is 500#, is probably at least as good a ballast as a 750# ballast box because the weight is so far back (a bbox typically starts much closer in, and the rc goes back much farther). Of course, you've got to pay attention when it's on because it swings so wide whenever you turn, so obviously the bbox wins on that account.
But if your bbox had a (heavy duty!) telescoping mount, you could have a compact (side to side) weight that still doesn't stick out as far as a bbox or bh (my typical ballast choice) but could easily provide 2x the ballast with little more construction cost.
/ Lifting safe - Ballast Box needed? #38
OP also mentioned a different loader which also shows up on TractorData as the H165 FEL. Threw me off, and now wonder if the 320R gives more (or less) lift to the JD 3046R tractor.
Interesting.
Ah, good eye. I had missed that, and also forgot that Deere still had that loader on the books when the 3046R was first released.
The 320R replaced the H165 shortly after the new 3R series was released. They have similar spec's, with the newer model having 1.5" more reach and height, but suffering a corresponding 100 lb. less lift capacity due to the longer torque arm. Due to the slightly shorter reach of the H165, it may be slightly less tippy on the same machine than my 320R, with the same load.
Glad OP is using a counterweight, anyway. Brush hogs aren't the most compact and convenient things to use, but it will get the job done.
/ Lifting safe - Ballast Box needed? #39
you should be fine, just take your time, if you feel the back end lift just set it back down. Also, make sure to have your tractor level when lifting high.
(INOP) INTERNATIONAL 1066 TRACTOR (A64278)
(INOP)...
KUBOTA 4 BASKET HAY TEDDER (A64278)
KUBOTA 4 BASKET...
2012 Mini Cooper Hatchback (A64557)
2012 Mini Cooper...
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
2011 Kenworth T300 S/A 18ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
