Lift pin spacing
/ Lift pin spacing #1
droy
Southwest Louisiana
NH Boomer 55, ZD1211
After pricing around, I bought a couple of new toys for my 1715 Ford from the local Case IH dealer. A friend accompanied me when I went to p/u the attachments, & he was also impressed with their prices, leaving there considerably lighter in the checkbook. The salesman noticed me looking at their quickhitch, & later called me & offered it to me @ a nice price for the added business. After bringing it home, I noticed I can only use it on a couple of tools, & will need to modify the rest. I'm wondering if there is a standard width for the lift pins on tools that are set up for quickhitch, before I start the modification project. Thanks in advance
BTW, we're talking Cat 1, as you'll probably already know
/ Lift pin spacing #2
Here is a link to a site that has 3PH dimensions. Click Here
Dimensions are at bottom of page.
Quick Hitches have been discussed here quite a few times. Do a search. Most of them experienced same problems you are.
/ Lift pin spacing #3
FWIW, you can increase or decrease non-standard implement pin spacing by installing them facing out, or facing each other. Sometimes that's enough to make them QH compatible, without going to the trouble of modifying anything.
//greg//
/ Lift pin spacing
Thanks for the replys, & in the future, will try to remember to use the search feature; I didn't think my situation was a common one, but putting a little thought into it, I can see I'm not the only tractor owner around. Also turning my pins "a half a round", won't work for me (not that lucky),but I do have a working relationship with Mr. Lincoln & Mr. Victor. Thanks again !!!
(2) 27x32 CIH Rims (A65640)
(2) 27x32 CIH Rims...
Engine knock
Engine knock
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2017 Mack Semi (A64047)
2017 Mack Semi...
