Ricn
Platinum Member
- Joined
- Sep 18, 2015
- Messages
- 555
- Location
- WA
- Tractor
- Kubota U-35, kx-040, Ford 8n, JD-280, JD380, JD1020, JD40C, Satoh Bull, Kubota L2501,
you sir are greasing wqy to much! flails use sealed bearings needing grease very infrequent. I say this after blowing mine out twice when new and finding out from a reliable bearings manufaturer why this happened. Now, and for several years, I grease them twice during the summer months pending how much I do mow and then just a couple pumps in each side. I have learned to listen to the mower as it tells us when something is amiss. Inspection is also worthwhile, look at the belts and all else several times each season, adjust as needed. Flails are great mowers but not without needs, they require more than just using them followed by parking someplace until next time. I never leave mine outside in the weather, it goes in the shop when not in use. Surely some will disagree here but time has proven what I've said plus, the manufacturer of the bearings I installed, (the best ones I could find being made in Japan) said over greasing is one of te biggest issues in the bearing world.
