Let there be light
/ Let there be light #1
tom1023
wallingford ct
John Deere 1023E TLB
I got these lights from ebay to mount on my JD 1023. I mounted them on the side of the Rops because I have to fold it to get in garage. All I can say is dam they are bright!!
photo 1 - Copy.JPGphoto 1.JPGphoto 2 - Copy.JPGphoto 2.JPGphoto 3 - Copy.JPGphoto 3.JPG
/ Let there be light #3
Do you have make and Model on the lights. They look sweet. Did you have running lights already that you had to remove? I have a 1025r and where you mounted these I have hazard/directional lights.
Let me first say, Thanks to both of you. Ok I don't have a model of the lights but if you search ebay for this # 130980021215 That will take you to them. I paid 130 for 4 of them delivered. I mounted them above the hazard lights. I didn't have the running lights so when I wired these lights, I used the switched power that was for those running lights in the dash. Take the left engine cover off and you will see it right there. These pics should give you an idea where I mounted them.
/ Let there be light #6
my neck hurts :D
HA-ha... I thought mine would too when first looking at this thread and the thumbnails... but... they show correctly (vertically) when you click them!
/ Let there be light #8
Tom1023. Did you make the bracketed yourself or did you find some parts and pieces somewhere?
I should be getting my first tractor in a the next weeks once the mid-pto and deck come in. I went ahead and bought 4 very similar lights and a light bar for the top of the rops. Was hoping to get lucky with some bracketry and those ubolts.
/ Let there be light #9
My leds make a BIG difference in lighting
I made them up from some brackets I bought at a local hardware store. I did do a bit of welding for u-bolt brackets
Geez coobie, those are doubles of my lights. I understand cause your tractor is bigger. lol
I've used leds before and have no complaints. I also put a pipe over the cutting edge to save the driveway from getting too scuffed up. It also doesnt dig up the lawn as bad.
(6) 8" X 8" TREATED TIMBERS (A63291)
(6) 8" X 8"...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2021 PETERBILT 367 (A63569)
2021 PETERBILT 367...
Snatch & Grab Tow Truck Bed (A64047)
Snatch & Grab Tow...
2007 FRAC TANK 500BBL WHEELED (A63569)
2007 FRAC TANK...
