Left Hand or CCW Mower Blade
/ Left Hand or CCW Mower Blade #1
jcalla
Triangle, VA
I am looking to find a left hand cut or CCW rotation mower blade that has the same specs as the attached file. Could someone please point me in the right direction? I just am unable to locate one. see attached files showing specs of Oregon 596-627
Thanks
  • Oregon Blade 596-627.pdf
/ Left Hand or CCW Mower Blade #2
That's a tough one. The only LH blades that I see are on John Deere Freedom decks. They have 1 LH in each kit. AM130172 is the number for something like a LT155.There are others in the Deere line up. They had LTR166 that had super high lift blades as well. You'd need to bore the center if you need a full inch. Oregon used to sell them, but got pinched? I guess on selling the LH blade.
Yeah, I been trying for several years to find heavier LH blades for my Landpride batwing finish mower. Stock LH blades a just 2" wide and don't have the force I am looking for in heavy areas.
/ Left Hand or CCW Mower Blade #4
As in high lift? Post the OEM number and I can check the Stens, Rotary, OEP for an upgrade if you haven't already.
T,
The mower is a 2017 Landpride AMF 4214 batwing finish cut pull behind mower. I want something heavier than OEM blades. The OEM blades are listed in the attached description for the Oregon blade 596-627. This specs out pretty close. Also, I like Oregon 396-612 because it is a little thicker even though I would have to drill out the center hole to 1". If I can find either Oregon blade in LH cut, I'm a happy camper.
J
  • Oregon Blade 596-627 for Batwing.pdf
T,
Attached you will find OEM number on second page.
J
/ Left Hand or CCW Mower Blade #7
I didn't see anything.
T, try it now
J
John Deere 6195R (A60462)
John Deere 6195R...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
Dual Rear Wheel Axle (A59230)
Dual Rear Wheel...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
UNUSED SDLANCH SDLJC HIGH END MOBILE JAW CRUSHER (A60430)
UNUSED SDLANCH...
