Left Hand or CCW Mower Blade
/ Left Hand or CCW Mower Blade #1
jcalla
Triangle, VA
I am looking to find a left hand cut or CCW rotation mower blade that has the same specs as the attached file. Could someone please point me in the right direction? I just am unable to locate one. see attached files showing specs of Oregon 596-627
Thanks
  • Oregon Blade 596-627.pdf
/ Left Hand or CCW Mower Blade #2
That's a tough one. The only LH blades that I see are on John Deere Freedom decks. They have 1 LH in each kit. AM130172 is the number for something like a LT155.There are others in the Deere line up. They had LTR166 that had super high lift blades as well. You'd need to bore the center if you need a full inch. Oregon used to sell them, but got pinched? I guess on selling the LH blade.
Yeah, I been trying for several years to find heavier LH blades for my Landpride batwing finish mower. Stock LH blades a just 2" wide and don't have the force I am looking for in heavy areas.
/ Left Hand or CCW Mower Blade #4
As in high lift? Post the OEM number and I can check the Stens, Rotary, OEP for an upgrade if you haven't already.
T,
The mower is a 2017 Landpride AMF 4214 batwing finish cut pull behind mower. I want something heavier than OEM blades. The OEM blades are listed in the attached description for the Oregon blade 596-627. This specs out pretty close. Also, I like Oregon 396-612 because it is a little thicker even though I would have to drill out the center hole to 1". If I can find either Oregon blade in LH cut, I'm a happy camper.
J
  • Oregon Blade 596-627 for Batwing.pdf
T,
Attached you will find OEM number on second page.
J
/ Left Hand or CCW Mower Blade #7
I didn't see anything.
T, try it now
J
