LED LIghts added to B2650
/ LED LIghts added to B2650 #21
Actually, LEDs are down to about $12 too! I bought some for my boat and got two for $22. A couple years ago I paid $120 each for the LEDs on my Kubota, which is nuts. Prices have really come down.
The crazy thing is that I see many sellers still offering the LEDs for big bucks, but they are the same Chinese knockoffs you can buy elsewhere for $12. So buyer beware with these lights.
?Link to seller? Pls :)
/ LED LIghts added to B2650 #24
/ LED LIghts added to B2650 #25
/ LED LIghts added to B2650 #26
Hi Porchfan,
Those lights look nice & toss a nice light in the woods!
You mentioned you're thinking of maybe using some external conduit for the wires. Would the conduit interfere with folding the ROPS down?
If you run the wiring inside the ROPS via drilling holes in your ROPS and run the wires inside the square tubing.... I suspect that would involve at least one or two 3/8" hole at the top and another at the bottom of the upright ......are you at all concerned about weakening the ROPS protection capabilities?
BarnieTrk
I route my wiring through air Brake tubing (common on fuel tankers). It will bend without kinking, protects the wire from kinking and can be attached to the ROPS with long cable ties.
/ LED LIghts added to B2650 #27
I just got a pair of these for augmenting my forward and rear 27W LED lights. They should light up the sides nicely. Mine were $18 delivered, and I am impressed with the apparent quality.
Amazon.com: Penton 2pcs 4" 18w Cree LED Work Light Bar Flood Beam 60 Degree Waterproof for Off-road Truck Car ATV SUV Jeep Boat 4wd ATV Auxiliary Driving Lamp-pack of 2: Automotive
Nice, Varmint. I'm looking forward to hearing how you like the spots once you get them mounted. I'm assuming from your comment that you'll mount them pointed directly out to either side. Not sure I'll add side lights to my NX4510, but was thinking floods would illuminate a bit better immediately to the sides if I do.
/ LED LIghts added to B2650 #28
Great idea. What diameter do you use? I'm thinking air brake tubing may be a better way to protect video camera cable than wire loom when I finally get around to installing my FEL bucket camera.
/ LED LIghts added to B2650 #29
Hey Varmint,
Those look good too, I guess momma will get the other ones 'cause she wouldn't like these ones on her car, but I'ma get me a pair of these too.
Thomas
/ LED LIghts added to B2650 #30
That would be interesting -- I have never seen air brake tubing. I used a combination of fuel hose and hydraulic sleeving (the black nylon stuff) to run camera wiring through the difficult parts of the FEL where there would be a lot of flex and abuse. Regular split-loom on either side of that section.
/ LED LIghts added to B2650 #31
Depends of number and size of wire. Have used 1/4 to 3/4 with good results. comes in green red and black colors depending on where you are running it
/ LED LIghts added to B2650 #32
Yup, I plan to mount them aimed a bit forward, but mostly down to the sides. I have one forward flood light, and one spot, but they are aimed directly forward, and in my case, downwards. There's still the problem of the loader or plow blocking light right down in front, but I don't have a solution for that. I just want light to see well in whatever situation I am in, and multiple LED's are low draw enough that I can do it without stressing the alternator or battery. The forward LED lights are so much more useful compared to the factory incandescent lights that it's sad.
/ LED LIghts added to B2650 #33
Ok..
I'm a real noob when it comes to wiring and setting these LED's up. I do know that I really don't like the way to loader blocks the lights in winter. I would like to place them on the side of my ROPS.
Is there a diagram / parts list that I can see visually.
The manual says that the cig lighter is 120 watts. Does that mean I can put a couple of LED forward facing on the ROPS sides, and one on the slow moving sign backwards and then connect them all to the cig adaptor if they are all together under 120 Watts?
I'm sure even I can splice them all together lol.
Ok knowledgable ones.. tell me the correct way :)
Thanks for your time
/ LED LIghts added to B2650 #35
Ok..
I would think yes. But I would have the front and back lights on two switches after the plug.
I could draw up a diagram but in terrible at drawing. My 6yr old sister makes me look like a noob
/ LED LIghts added to B2650 #36
I think that idea is a good one.. the switch :)
I think I can get the wiring routed ok too.
I googled the switch, but I can't seem to find one that I had in my mind.
Perhaps I'm searching for the wrong term.
Any idea were I can find a switch, or housing for them?
/ LED LIghts added to B2650 #37
Don't forget, 120 watts is 10 amps, which might be all your circuit is fused for. You can get nice, waterproof switches via eBay for under $5 apiece... If your Kubota is like mine, there's a 10 fuse on the fuse block for "work lights" and an unswitched wire to use, with two wires back to the rear of the fenders for lights. I just carefully cut two rectangular holes for the switches where the plastic dash panel was void behind the front.
I didn't see what model Kubota you have, but many of them have natural mounting locations on the ROPS hinge area which doesn't compromise the strength, and puts them in the right spot, in terms of height, protection from side impacts, and keeping the ROPS clear for things like auger handles, etc.
Send me a PM if you want, and I will send you the link for the switches I used.
/ LED LIghts added to B2650 #38
Just got a B2650 that has a dynamo instead of an alternator and was concerned about drawing too many amps if I added aux lights. I found 2- LED aux lights on ebay for $20. these lights draw 18 watts of power each and have 1800 lumens . I also ordered 8 -1156 Led replacement bulbs for all the other lights. (2 headlights, 2 for the flasher , 2 side flashers and 2 for the taillights.) These led lights draw 3.29 watts and put out 240 lumens each, cost $10for all. That's a total of 62.34 watts. and with a battery voltage of 12.6 volts, it equals out to about 4.9 amps of drain on the charging system. I've heard that the dynamo puts out about 10 amps max. so I did some checking and at 1300 rpms with all lights on including the flashers, battery voltage holds at 12.8v.
/ LED LIghts added to B2650 #39
If you want to upgrade to an alternator setup, the 40 amp upgrade kit from Kubota for the B2630 works on the B2650 as well. Took a chance and ordered one to try and installed it yesterday, everything plugged in and bolted up as it is supposed to.
/ LED LIghts added to B2650 #40
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2015 Ram 5500 RKI 10ft. Utility Flatbed Truck (A64194)
2015 Ram 5500 RKI...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
Galvanized Metal Roof Vents (A64194)
Galvanized Metal...
2007 Ford Fusion Sedan (A64557)
2007 Ford Fusion...
