LED LIghts added to B2650
/ LED LIghts added to B2650 #1
Porchfan
Oak Ridge, NC
2013 Kubota B2650 HSD, 2020 BX2380, JD LX-277 lawn tractor 2000
Added a couple TS LED work lights Navigator 4 in. Round Heavy-Duty LED Utility Light | TractorSupply to the ROPS on my B2650. I fabricated a steel bracket / clamp for the lights so no drilling into the ROPS was required. The spacing between the center of the bolt holes was exactly 1.75 inches. When you use a 1/4 screw, that aligns the inside difference to 1.5 inches which is the thickness of that side of the rops. I clamped it together with six 1/4-20 four inch screws. I then routed the wire down the rops to the cigarette lighter near the arm rest. I'll probably either put the wires inside the ROPS square tubing or run it through conduit when I'm done. Here's a short Youtube video of the mods I made. Check it out...
The work pretty good. Here's my trek I made at dusk tonight.
/ LED LIghts added to B2650 #4
Nice work! I'm looking for something to add to my ROPS to help with winter time snow blowing. Also thinking about a light bar too....
/ LED LIghts added to B2650 #5
Hi Porchfan,
Those lights look nice & toss a nice light in the woods!
You mentioned you're thinking of maybe using some external conduit for the wires. Would the conduit interfere with folding the ROPS down?
If you run the wiring inside the ROPS via drilling holes in your ROPS and run the wires inside the square tubing.... I suspect that would involve at least one or two 3/8" hole at the top and another at the bottom of the upright ......are you at all concerned about weakening the ROPS protection capabilities?
BarnieTrk
/ LED LIghts added to B2650 #6
Nice work and video, Porchfan! Have you thought about adding a wheelspinner to that steering wheel? You can make that drive to the woods one-handed. CountyLine Deluxe Wheel Spinner - For Life Out Here I finally got around to putting one on all three of my machines, and now wouldn't be without them.
/ LED LIghts added to B2650 #7
Really like the 2650 and the light addition.
if you decide to add the spinner, look at the dealer also, really liked the quality of the Kubota one and it was only a few bucks more.
/ LED LIghts added to B2650 #8
Not to diminish your work Porchfan, but here's a video of my Amazon $11 27W lights in blackness.
4 front, 2 rear, sides are 18W as is the middle utility in the back.
I'd also suggest running the wire inside the ROPS.
/ LED LIghts added to B2650 #9
Hi Jim,
Did you have to drill holes in your ROPS structure to run the wires inside it?
If so, are you at all concerned that you may have weakened it by drilling holes in it?
BarnieTrk
/ LED LIghts added to B2650 #10
My ROPS is 2x3x.250 tubing. I put one .250" and one .375" hole in the inside of the 3" dimension for wiring, and two .250 threaded holes in the center of the 2" dimension for mounting the light bar. I'm not concerned at all about weakening the structure. There's two .375" holes on the top back of the 2" dimension from the factory at a similar distance from the radius to where my additional holes are.
You can poke a lot of holes in tubing and not diminish it's strength to any degree. It's more about how much material you remove and how close to the corners you remove it. Lots of paranoia around here about the ROPS that's unfounded.
There is one hole already at the top of the rops. I think I might be able to squeeze the wires through that. At the end of the square tubing down near the transmission, the tubing is open so the wires can easily be run out there and then into a FLEXABLE wire conduit. If I cannot get the wires through that single hole at the top, I don't think another 1/4" hole will hurt the integrity of the Rops.
Very cool. The lights I bought were LEDs. Much more expensive than incandescent ones. Are your $11 lights LEDS? LEDs should last forever as long as I don't hit them on a tree or worse by rolling the tractor.
/ LED LIghts added to B2650 #13
Actually, LEDs are down to about $12 too! I bought some for my boat and got two for $22. A couple years ago I paid $120 each for the LEDs on my Kubota, which is nuts. Prices have really come down.
The crazy thing is that I see many sellers still offering the LEDs for big bucks, but they are the same Chinese knockoffs you can buy elsewhere for $12. So buyer beware with these lights.
/ LED LIghts added to B2650 #14
Yep! I just ordered some 18W LED lights for side lights, and discovered the same seller offering them for $9 delivered to $150 delivered, but the more costly version was 2nd day shipping vs. 3-4 day shipping. Go figure. Same lights, according to the descriptions. I look for Cree LEDs, but you gotta wonder if they really are?
/ LED LIghts added to B2650 #15
Mine are all LED's. The only incandescents are the factory rear aux light and the headlights. Whole installation was around $100. Money well spent IMO. :)
/ LED LIghts added to B2650 #17
The ones on the fenders are speaker boxes. Yes. I have a couple more I'll be adding for storage on the tractor. I have a couple on my logging winch for storage as well.
/ LED LIghts added to B2650 #18
I wonder that as well. Cree is tossed around a lot, but there is no way to verify short of tearing the light apart and looking at the LED element. I suppose even that could be faked.
/ LED LIghts added to B2650 #19
Shopping at Walmart in Colorado reveals that they have a nice selection of LED's for $20-25 a pair. These are narrow linear lights not round or square.
/ LED LIghts added to B2650 #20
You can try the wally lights and return them if they don't meet your needs.
Amazon has free returns too. Just saying... :)
2005 Dodge Dakota 4x4 Crew Cab Pickup Truck (A64556)
2005 Dodge Dakota...
2002 MITSUBISHI FG40K FORKLIFT (A66091)
2002 MITSUBISHI...
LAND PRIDE 10' HYD 6 WAY BLADE (A64278)
LAND PRIDE 10' HYD...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2014 Peterbilt 337 S/A 18ft. Cab and Chassis Truck (A64194)
2014 Peterbilt 337...
