LED LIGHTING REVIEW
/ LED LIGHTING REVIEW #21
Thanks Dooley. Laying in bed sick with the flu so can't go out there right now but I do believe they have a reflector system in them. I think I'll just order two of these 27w versions and be done with it. Thanks again, Mark
/ LED LIGHTING REVIEW #22
I'm in the same boat. Caught some sort of nasty bug that has me limited to the office, the bathroom, and bed. Not exactly how I wanted to spend a few days off.
Pass the NyQuil please Mark.....
hope you are feeling better soon.
i have 3 kids under the weather this week.
pass the Lysol
tom
/ LED LIGHTING REVIEW #24
BIG DOOLEY said:
I think i said in one of the early threads mine are flood pattern.
both sets are flood pattern.
there are no reflectors to concentrate the light into a spot.
do yours have some sort of reflector to make the spot beam?
can you post a picture ot the lens front.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287198"/>
Tom
You said it on 10/31/12, and apparently heckofaguy didn't see it.
That square panel design with minimal reflector describes some lights I got from LED Warehouse on Amazon.
Very bright, but pure flood without any focus point. I'm thinking about adding shutters to better focus them, like on klieg lights.
Thomas
No matter where you go; there you are...
Morning,
Thanks, I would hate to mislead or steer someone down the wrong trail.
Off the topic I have a fresh 28 F morning in Michigan today with some light frost.
Shutters might be a great solution to many peoples debate of which set to purchase.
I doubt that you will get a strong "beam" , but it should have some effect on redirecting light.
I might suggest try using a shutter set that you can move to change from spot to flood.
Heck it would be a simple experiment bench testing off the tractor.
Shutters would also be a great solution to lights mounted directly overhead on the ROPS where too much light is in the face while looking back etc.
My lights are mounted for and aft of the operator station and I do not not have this issue but others have sounded off on the problem before.
Aluminum dryer vent tubing??? or some other reflective material clamped around the perimeter of the light might be a solution.
Experiment with different lenghts and shapes. A visor shape would collect the light trying to go up.
Anyone looking for a spot beam remember this.
A parabolic reflector is what redirects the light into a spot beam. if the lights have no type of reflector is is not going to be a spot light beam.
Tom
/ LED LIGHTING REVIEW #26
Morning,
Tom
Good thoughts that [if it pleases you to excuse me] mirror my own.
Thomas
/ LED LIGHTING REVIEW #27
I just added the 2 x 18W versions from the same place. I put them on yesterday and all I can say is WOW. I got them working yesterday afternoon and tried them out last night. What an unbelievable amount of light they throw off. Thanks for the tip!
I may need to add one more for facing back. Shortsightedness on my part.
/ LED LIGHTING REVIEW #28
tkappeler, I've had good luck with the ones from tractorhelp.com also. Lights.....can you ever have enough? haha
Great!
Sounds like everyone who buys a set has the same reaction "WOW".
Nice loooking tractor by the way.
Big Dooley
/ LED LIGHTING REVIEW #30
When I ordered my pair of 18w lights, I had a choice of flood or spot. Since I will be working withing 15'-20' of the lights mostly, I went for the floods, but the spots might work better for some users? For $26 each, you get a good light.
/ LED LIGHTING REVIEW #31
My TruckLite's in use since '98 are still going strong. I have 2 Trapezoidal (work beam) lamps mounted top of windshield below roof overhang, and later purchased 2 floods for the rear; but before installing the rear I tried out the flood in the garage and outside at night and found the flood a little to wide and not enough reach mounted up high. Ended using 1 flood and purchasing 3 more traps, and used 1 flood and 1 trap at the rear keeping 2 traps on the shelf for future use. A friend has a spot beam and it would not seem to useful as aiming it just a reasonable distance leaves too many dark areas to the sides. The traps seem to work the best of all with wide side coverage and lots of reach due to the narrower, more concentrated beam from the top of the lamp. No reflector is used; just the fluting of the lenses shapes the pattern, and since the LED's and the lens can't be removed from or rotated in the housing they can only be mounted 1 way, usually base down. Several manufacturers make PAR 36 LED assemblies that will fit common lamp housings both rubber and metal that have the ability to be indexed if needed, and are very bright, but a little below lamps that have more heat sink area. I notice a lot of lamps on tractors on this site do have the lamp mounted base up, but it does not matter on a spot/flood/pencil beam what clock position is used, and most fog lamps if needed could be mounted 180 degrees out. I mention all of this since the trap beam has always been the most popular on almost all equipment, and seem to be the best beam compromise. Just make sure to see if the mounting base has optional positions or the unit has either the ability to rotate lamp within housing, or has a separate lens, like the Grote Trilliant which has LED board fixed in a die cast housing, and several lenses to choose from which can be flipped on the traps to get proper beam dispersion.
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
2006 GMC C5500 4X2 BUCKET TRUCK (A59912)
2006 GMC C5500 4X2...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
2018 Kia Soul SUV (A61574)
2018 Kia Soul SUV...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
