Learning how
/ Learning how #21
Thanks for the thoughts, K0UA.
I will definitely want to be able to do things like: repair a crack in the bucket of myloader, make a hitch "add-on" for my ballast box so I can move the loaded snowmobile trailer to snowblow without pulling off the box, and make some frames for various tasks around the garage. I would guess that a large part of what I would need to work with would be angle iron or the flat plates of steel of the tractor.
If I understand your comments correctly and have applied the information against what I'm certain of for use, it sounds like a DC stick welding system would be adequate for me.
The best weld for the money is an AC stick. If you stay with 6013 or 7014 rods you'll be pleased with the results. If you can buy a used unit you'll likely be able to sell it for what you bought it for, and you're not out anything to try it.
I'd suggest you get a used AC stick machine. Burn about 10 pounds of rod on scrap and non-essential projects. You may find that you're happy with the AC unit and you can spend your money on other things like band saws, sand blasters, O/A torch, and the list will go on.
/ Learning how #22
Some questions about this, then...
1) How will I know if I'm "happy" with this sort of set up or should move on to try something else?
2) Why would you recommend AC over DC or combo? How are they different?
3) If this isn't the best setup for me, what would I "move up to" from here?
4) Any suggestions on specific brands / models to look for in the used market? And, at what approximate price point?
/ Learning how #23
As you weld you'll start feel whether you want more or not. DC lends itself to more flexibility. If you get to the point with AC where you wish you could do more, you may move to DC or some other process. AC is still a good place to start.
Price.
DC is a better process because of the flexibility mentioned above, but you can get into a used AC unit for a lot less money that a DC unit. Plus, you see the AC units come up for sale on the used market more often. (Because we all think we need to upgrade to DC).
AC stick is the best value for a homeowner or hobbyist to get started welding, AND it does a pretty good job.
It will depend on what you feel like you need... Do you wish you could weld better on thinner metal? (get a MIG). Do you wish you had more rod options or more flexibility for thicker stuff? (get a DC unit). Do you wish you could weld better on different types of metal? (get TIG). There's no one best welder. It really depends on your style and what you decide to do with your machine.
Any brand you recognize is a good option... Hobart, Lincoln, Miller, etc. I had an old montgomery ward when I first started, and it did a great job. You should be able to get a good used AC stick welder for about $150... less if you're patient and willing to buy an ugly one.
/ Learning how #24
Thanks for the input.
I'm torn between a used AC and a new DC since I could buy a new DC unit for about $100 more than a used AC one (I don't like buying stuff used from people I don't know unless I'm very familiar with the product and can do a thorough checkout on it - I take excellent care of my stuff).
Excellent information to have, though, no matter which way I end up seeing this play out.
This is why I love forums like this... Lots of great people, with lots of experience and knowledge, and a willingness to share with others to help them learn.
/ Learning how #25
I would think a plan would be to take some courses at the Lincoln Welding school in Cleveland, esp. if you're close. MIG, TIG and OA about a week each.
/ Learning how #26
For me, I'm not in that area (and I just realized that my profile didn't have any info so I updated it). I am going to explore possible Voc/Tec school options where I could learn or even pairing up with another member in the area that would possibly be able to give me some first-hand info.
/ Learning how #27
Do yourself a big favor and get a DC welder if you go stick. I remember going to welding school and certifying with DC welders. I bought a like new AC welder off my neighbor and I had to learn all over again. It was so more difficult to use and not as much choice in rods. JMHO
/ Learning how #28
I'm almost afraid to mention this because of the attacks I may get , but here goes. A ac machine is more damgerous than a dc machine. More cases of electrocution . My dad and brother were pipefitters of combined 70 years and they wouldn't let anyone they knew buy a ac machine without warnig them of dangers they witnessed . Just study it for yourself. I have .
/ Learning how #29
I hadn't heard that. What makes AC more dangerous?
/ Learning how #30
I don't know the whole story byemory but you can look it up on net. Ac has different effects on the heart than dc. Something about fibullating effect causes heart attack.
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
(2) John Deere Row Markers (A60463)
(2) John Deere Row...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
1991 TRAILMASTER CRUDE TRAILER (A60736)
1991 TRAILMASTER...
Kuhn FC400RG (A60462)
SDlanch 20'x20' High End Carport (A60463)
SDlanch 20'x20'...
