Intro into Brazing
/ Intro into Brazing #41
I would like to learn to braze. I have been looking at the benzomatic kit that uses a small mapp and oxygen tank.
GOOGOL YOUTUBE for "benzomatic mapp gas brazing"
I hit on a couple of good ones. Of course you can always go bigger - if you're into a lot of it, the price of those non-refillable tiny tanks will justify a set of PONY TANKS and torches ($295-$420 New Home Depot today). I could NOT find the Mapp/Oxy combo at Lowes or HD to day!
Look at the videos, see how it is done (regardless the torch/setup employed). That at your expectations/intended projects should help you decide if the MAPP GASS approach would be worth the learning curve
/ Intro into Brazing #42
Umm...Can we get back on track, first off TIG is only going to solve problems for a few welders with equipment and skill..... MIG is probably best for intermediate welding for most small farm and hobby farm applications.... Brazing is entry level for small repair usually for people with Oxy/Acet rigs.... I personally only have Hobart Handler 140 for welding and it does really well for most all my needs, my Oxy/Acet rig has been relegated to mostly heating and "some" cutting.... Tried TIG, its to demanding for old eyes and not to steady hands.... As pro welder at demo stated, I was pretty good at balling up tungsten tip....
/ Intro into Brazing #43
Your local voc/tec evening class is the best way to learn. They would also know how to get and fill welding cylinders.
For soldering, silver soldering, and brazing a clean, rust free surface and the right flux for the material is all important. A company called Eutectic makes really good flux.
They used to make a kit for silver soldering with a few rods and flux. If you have a local welding supply shop, they would have it. Not expensive. They could also tell you if you could use Mapp gas for it.
/ Intro into Brazing #44
I am currently running .030 flux in my welder but I do have gas hook up capabilities. Will gas MIG work better on thinner material than flux?
I dunno which machine you have but with my Lincoln SP125+ and SP100 machines I can weld sheet metal easily. Normally when you switch from flux core to MIG you also need to switch polarity. But Lincoln says for sheet metal the polarity should be the same as for flux core welding. Of course the voltage and wire speed must also be reduced quite a ways. And you need to use .023 wire. With my old Lincoln machines this is easy since they have infinite wire speed and voltage controls. I don't know if your machine has this flexibility.
Eric
/ Intro into Brazing #45
IF you are half way serious about oxy/acet brazing you really need serious torch set.... THE the big box store sets with 16 oz oxy and mapp gas are just enough to make you really frustrated..... Personally I would not go smaller than the style shown of graphic below..... To learn to braze, there is a dozen or more videos on u-tube to show you how.... The problem with smaller sets is finding a gas supplier that will work with you handling such small cylinders.....
I totally agree, once you have the bottles and torch your world will open before your eyes, brazing, light steel welding, welding copper with silfos, heating and bending, cutting and more. Here in New Zealand Bunnings hires the bottles, one lifetime cost and when my blood stops pumping my Kids take the bottles back and they get that payment back. the bottles are alot bigger than pictured above.
/ Intro into Brazing #46
you mentioned having a hard time brazing a hole one thing a lot do wrong is just heat the hole, you have to generate a lot of heat around a hole and test your brazing rod for even flow when that starts around your hole keep everything hot and push the rod in the hole it will fill nicely I was a maintenance machinist for 35 years we use to repair all kinds of things wore out shafts were one thing we did a lot of or wore out bores for a bearing, we would undercut the shafts and build them back up, same on outer bores for outer race of bearing worked very well with brazing rod and silver solder repaired a ton of equipment saved them a ton of down time and money
/ Intro into Brazing #47
For all types of soldering, brazing, or welding, I enjoy the oxy/acetylene torch the most. It is so versatile and relaxing. It can add or subtract metal, join weird alloys together, heat treat, and stress relieve. What a marvelous tool.
rScotty
/ Intro into Brazing #48
This was before wire welding came out also and this could be done nicely with a wire welder also
/ Intro into Brazing #49
I do eventually want to get my hands on a torch set. Just hasn't been a big enough push to need it. Since I already have a MAPP torch and all I would need it flux and rod, I may just play around with it before investing any more. If this set up is enough to do a chainsaw exhaust, it may really be all I ever need.
Look for a victor style torch set on marketplace or craigslist or at your local pawn shop. I bought a used 'Victor Journeyman' torch kit for ~$100 3 or 4 years ago from ebay. Had everything I needed but the bottles.
/ Intro into Brazing #50
Would that kit be enough to braze something like a chainsaw muffler?
How about a picture of what you're talking about? Is it mounted on the saw - or can you remove it to do the work? Brazing thin to thick (or vise versa) can be a bit difficult. Since you need to heat the material red hot +/- the thicker the material the more MAPP gas required and the kit tanks only hold 14oz - since you can't change out a tank before the metal cools . . .
2017 Volkswagon Passat Sedan (A59231)
2017 Volkswagon...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
