Intro into Brazing
/ Intro into Brazing #51
How about a picture of what you're talking about? Is it mounted on the saw - or can you remove it to do the work? Brazing thin to thick (or vise versa) can be a bit difficult. Since you need to heat the material red hot +/- the thicker the material the more MAPP gas required and the kit tanks only hold 14oz - since you can't change out a tank before the metal cools . . .
That kit will do anything yo will probably ever want to do.
For your muffler a very small torch a 000 or 00 tip would work. I don't know if you would need to up to a 0 tip. You will need to practice on some thin stuff first. unless you take a class at a tech school or Jr collage.
I learned as part of my air craft mechanic training and 40 years later when I wanted to start doing stuff I went to the local Jr Collage for refresher training. It was well worth it . Ok some more thoughts on the kit: I bought a 80CuFt acetylene bottle which means I can not use any gas large tips because that small a tank can't produce enough acetylene for a large tip (>3 or maybe 4 size for welding and a size 1 rose bud for heating) I kept the sizes small because I loose tract of time and acetylene production drops to a lower level after a few minuets.
I welcome any corrections from the better than me guys here.
/ Intro into Brazing #52
I don't normally comment, however I had jump in here. About 18 years ago I took an intro to welding class at the local tech high school. Course was 2 nights a week for 8 weeks. Covered O/A stick & mig. Both flux & gas. Cost was $220. Now it is a four week class that has been split into two separate courses. The kicker is that EACH course costs $999. Two grand for an intro class is a little too steep for me.
A few years ago I was interested in taking the course again, but was then about $650.
Al
/ Intro into Brazing #53
I think with common sense, a bit of hands on and a few U-tube vids most people can get the just of it.
I can weld ok for a I guy who learned on a stick in the farm shop as a kid. I've done some learning in our schools AG shop. I just like having the option to have the freedom to do my own work. My grandpa didn't buy something until he could make it or fix it. Junk and scrape all around just waiting to be turned into something. I inherited that gene.
/ Intro into Brazing #55
I do eventually want to get my hands on a torch set. Just hasn't been a big enough push to need it. Since I already have a MAPP torch and all I would need it flux and rod, I may just play around with it before investing any more. If this set up is enough to do a chainsaw exhaust, it may really be all I ever need.
It would likely do the job for you. If you are referring to the muffler that would be a challenging first job unless you have a lot of soldering experience. It involves getting the workpiece to just the right temp and then applying the rod. The thinner the workpiece the shorter the window between just right and oops I have a big hole now!
/ Intro into Brazing #56
I didn't know this thread existed. I mainly use my Oxy-acetylene kit for cutting or heating metals with a Rosebud. Now that I have a Plasma cutter, I cut more with it. I have a gate that is made out of Aluminum, and a buddy of mine who teaches welding fixed a crack with a tig, but it didn't hold, so another buddy told me to try and braise it, so I just started looking into it. I haven't braised in over 30 years and don't remember any of it so will be watching some videos. I use a heavy-duty Victor-style torch set. Does anyone know what Braising tip size is needed for Aluminum? I have none...thx
Plate ThicknessTip Size
1/8 inches000
1/4 inches00
3/8 inches0
1/2 inches0
3/4 inches1
1 inch2
2 inches3
3 inches4
4 inches5
/ Intro into Brazing #57
I once employed a guy that could weld anything from eggshells to the crack of dawn!! That may be a slight exaggeration but I learned a whole lot from him. I would estimate about .06% of his knowledge. Amazing is an understatement for his abilities.
/ Intro into Brazing #58
You and I might be related because that describes me and my grandpa to a tee.
Bad news first, all the kings horses and men can not successfully braze the chainsaw muffler. The tiniest bit oxidation/rust makes it imposable to braze and I assure you the muffler has pits that will not grind out before grinding through material.
The good news is you map/air torch works great on propane. Real mapp is no longer available and even if it was it's far more expensive and not much hotter than propane. You can buy a hose that will connect your Bernzomatic torch to a grill bottle and one grill bottle would last you 20 years. Buy a can of flux (half pint size will last nearly long as the grill bottle :giggle: plus you will use the flux for something in addition to what i'm about to suggest. 20 Mule Team Borax is also a good flux. There are dozens of heat ranges in Bernzomatic torches and unfortunatly it's difficult to know heat capabilities unless bought new in package. Strip out 14 ga and multistrand copper wires to find what size your torch can melt. Geather pieces of scrap steel for pratice and determine what size piece your torch can handle.
Ok lets get started. Begin with thin wire and a piece of steel the size of a knife blade. Briefly hold wire in outer flame then quickly dip into flux. Secondary flame of propane is hottest part (acty is inner flame). Hold flame near end of material until color changes then begin touching fluxed wire to material until flux melts and spreads followed by wire melting. Move along material while intremittenly adding wire (don't forget to dip wire in flux as needed). This costs next to nothing so pratice and experiment to your heart's content.
/ Intro into Brazing #60
Ignorant novice question: My ancient 230a-AC stick welder came with a carbon arc torch. Is this usable for brazing, or for heating/bending steel? I've never used it for anything.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
2004 John Deere 4720 (A60462)
2004 John Deere...
2011 INTERNATIONAL 4400 (A60736)
2011 INTERNATIONAL...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
