Leaking fuel injector assembly
/ Leaking fuel injector assembly #1
Ben755
Tx
Yanmar FX28D
I was in the process of changing out the glow plugs on an FX28D, and I noticed that diesel fuel was accumulating on the block near the first fuel injector. I traced the leak to the base of a threaded coupling that the injector screws into. Of course, fixing the problem will require opening the lines and removing the injector. My concern in trying to start the tractor after the fix - anybody have any experience with this ?
/ Leaking fuel injector assembly #2
I would think just bleeding that one injector should do it.
/ Leaking fuel injector assembly #3
I wouldn't worry about getting the injector in 9f you got it out. Bleeding air shouldn't be hard as said at worse you need to crack the line till fuel is present the tighten it.
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Caterpillar 302.7D (A64126)
Caterpillar 302.7D...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
Unverferth 330 (A64126)
Unverferth 330...
