Leaking fuel injector assembly
/ Leaking fuel injector assembly #1
Ben755
Tx
Yanmar FX28D
I was in the process of changing out the glow plugs on an FX28D, and I noticed that diesel fuel was accumulating on the block near the first fuel injector. I traced the leak to the base of a threaded coupling that the injector screws into. Of course, fixing the problem will require opening the lines and removing the injector. My concern in trying to start the tractor after the fix - anybody have any experience with this ?
/ Leaking fuel injector assembly #2
I would think just bleeding that one injector should do it.
/ Leaking fuel injector assembly #3
I wouldn't worry about getting the injector in 9f you got it out. Bleeding air shouldn't be hard as said at worse you need to crack the line till fuel is present the tighten it.
2022 EZ-GO ELITE...
2013 John Deere 825I (A64127)
2013 John Deere...
2007 Top Brand Deck Over Trailer, 18'+3' Dovetail (A62679)
2007 Top Brand...
John Deere 2032R Loader Tractor (A66285)
John Deere 2032R...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
