Lawn Boy 30" Rider
   / Lawn Boy 30" Rider #1
Dougryan
Webster, NY
Cub Cadet 3206
Hi all,
I have the mower deck from a LB 30" rear engine rider that I plan to use as a tow behind mower.
It came with the spindle, blade, and pulley. It's an 8" diameter pulley with a 1/2" drive belt.
My plan is to power the deck with a repurposed pressure washer motor. B&S 875 series (6.5hp).
I need to take it all apart and measure, but I believe the motor has a 7/8" crank shaft with 2 keyways.
My question... How fast should the 30" spin? In other words, what size pulley should I get for the motor crank shaft?
I tried finding lawn boy part details to see the size of the stock drive pulley, but the mower is so old all of the parts are obsolete and I can't find the detail I'm looking for.
Thanks in advance,
Doug
Here is the pulley on the deck spindle.
   / Lawn Boy 30" Rider #2
Here from the internet, a tip speed calculator:
Entering the blade diameter of 30inches and the suggested tip speed of 19000 fpm gives this:
Tip Speed Calculator
Enter any 2 values to calculate the missing variable
Diameter 30 Inches (in)
RPM (Revolutions Per Minute)
2419.16
Tip Speed 19000
Richard
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
CFG Industrail MX15RX (A53317)
CFG Industrail...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
