Larger hydraulic pump for YM2310?
/ Larger hydraulic pump for YM2310? #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I might need a larger hydraulic pump if the power steering is too slow. I looked for but was not able to find a larger displacement pump listed for my YM2310. Anybody know if there is a larger displacement pump that will work for my tractor? Maybe from a different tractor model?
Thanks,
Eric
/ Larger hydraulic pump for YM2310? #2
They are designed to be well matched to the engine power output. Imagine if you did find a larger displacement pump that would fit you're going to have a larger horsepower draw with less power available for traction. Have you looked into PTO pumps?
/ Larger hydraulic pump for YM2310? #3
What type of power steering does it have? A rotary valve column, power assist column or hydraulic rack and pinion? Have you tested the pressure?
/ Larger hydraulic pump for YM2310? #4
Thanks,
Eric
If going larger works, I would stick with the YM2x10. Saying a YM2410 or a YM2610 pump could be an option should it fit or bolt-on like plug-n-play. The one on the YM2610 is like the YM2500 aka John Deere JD850/JD950/JD1050.
