Larger hydraulic pump for YM2310?
   / Larger hydraulic pump for YM2310? #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I might need a larger hydraulic pump if the power steering is too slow. I looked for but was not able to find a larger displacement pump listed for my YM2310. Anybody know if there is a larger displacement pump that will work for my tractor? Maybe from a different tractor model?
Thanks,
Eric
   / Larger hydraulic pump for YM2310? #2
They are designed to be well matched to the engine power output. Imagine if you did find a larger displacement pump that would fit you're going to have a larger horsepower draw with less power available for traction. Have you looked into PTO pumps?
   / Larger hydraulic pump for YM2310? #3
What type of power steering does it have? A rotary valve column, power assist column or hydraulic rack and pinion? Have you tested the pressure?
   / Larger hydraulic pump for YM2310? #4
Thanks,
Eric
If going larger works, I would stick with the YM2x10. Saying a YM2410 or a YM2610 pump could be an option should it fit or bolt-on like plug-n-play. The one on the YM2610 is like the YM2500 aka John Deere JD850/JD950/JD1050.
2017 Scag Cheetah 61in Zero Turn Commercial Mower (A59228)
2017 Scag Cheetah...
John Deere 5075E (A53317)
John Deere 5075E...
Sellick S80 (A60462)
2026 tilt trailer (A56859)
2026 tilt trailer...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
2006 Mac Truck CXN613 (A56438)
2006 Mac Truck...
