Landscape Rake Build
/ Landscape Rake Build #201
But it's a rake? With springy tines.
How much of a load do we think it's gonna have at worst of times?
The tines are gonna flex far before any mounting flange or bolts shear.
jimgerken said:
360 degree rotation ??? Nope, I didnt see that one coming. Guess I gotta go back to work on mine. Really, that thing is a work of art.
Hey Jim,
Thanks for checking out my rake build and your compliment, True, it could be considered a work of art, but it will be art put to good work.
After I read your rake project and saw the video of the articulating action, I thought that was just way cool and mine had to have that feature as well, so I changed my design mid construction to copy that feature. You done good with your design and construction and I wanted one at least as nice as yours.
Renze - :confused:
Not sure what you mean, what exactly is the "dead point" thats going to cause my rake to self destruct?
Here is a quick review on some of the construction:
The tine holding bar spindle pin is solid cold rolled steel 2-7/16" (62mm) OD, the boom is 4" x 4" x 3/8" thick wall square tube, cylinder mounts are 1" thick bolted on with four grade 8, 1/2" socket head cap screws (shear strength for one 1/2" grade 8 bolt is around 17,870 pounds). I could ram this thing into a battle ship, first thing that would happen is the TPH drag links would collapse. Maybe reconsider your observation?
Nickahawk said:
GuglioLS, your landscape rake is looking pretty professional. You should start a little business of selling the plasma cut pieces!
Thanks Nickahawk, since I have not been flooded with parts request, I think I'll keep my day job. :D
tlbuser said:
Larry, you may be setting the bar a tad high for the rest of us to follow :) Great project, photos and storyline. Now for the dumb question.........How come you just didn't make the 360 blade interchangeable with a rake or a combo unit :confused:
Good question - just lazy I guess? no really, I just wanted a stand alone rake built from the ground up. I didn't want to mess with, or mess up the 360* blade as it works perfect the way it is. The 360* blade is a 6 footer, the rake is a 7 footer, the boom on the 360* blade is just long enough to allow it's 360* rotation and would not accommodate the 7' length of the rake. Beside that wouldn't it be a pain every time I wanted to swap from blade to rake? I mean, taking off just the blade part, then swapping it out for the rake seemed like more work to me than simply changing out TPH implements. That and the rake has articulation whereas the blade does not. How about I add a retractable blade to the rake? Maybe that would work out? I have a 10' hardened cutting edge. I found it laying on the side of the road may years ago. It's around here somewhere, I should go find it. I think it fell off the county road grader.
Hey Skunk - my thoughts exactly, no way will any of the bolts shear - ever. A 1/2" grade 8 bolt has 17,870 pounds of shear strength, The cylinder mounts are bolted on using four of those bolts for a total of 71,440 pounds shear strength. If I ran this into a brick wall, the wall would crumble, if I ran the boom into a solid rock cliff the tines would snap, then the TPH drag links will buckle, but before that I would have pushed in the clutch and nothing bad would have happened. I don't understand, I have not even used this thing and it's demise has already been forecasted. I guess I better post some video of it in action before it theoretically falls apart.
Larry
/ Landscape Rake Build #203
Hi Larry, The dead spot he is talking about is when the cylinder is in line with the king pin, and all movement has stopped. There is one spot on the rotating plate that this could happen, either pulling or pushing. This probably will not occur if there is some motion.
Hi J.J. -
OK got it, in other words; Bottom dead center of the cylinder stroke when it's being rotated to change direction. At that point, the angle of the tines is so great it could not be used to rake in that position. As demonstrated in the video, when rotating the tines as long as I change direction on the valve fast enough, the inertia / momentum rotates the tine assembly past that bottom dead center point. I got it "stuck" there a few times practicing until I got the timing down, all I had to do was give it a little nudge (by hand) past the bottom dead center point to get it "un-stuck". One time when it was "stuck" at that bottom dead center point, I had kept cycling the cylinder at full hydraulic power and nothing broke. The rotate cylinder is 2" diameter, the system hydraulic pressure relief valve is set to 2300 psi, if my calculations are correct, that's 7,222 PSI of pushing force available from the cylinder which is peanuts compared to the beefy construction, I think it will be OK.
Larry
/ Landscape Rake Build #205
Larry,
If I am thinking right, and you get in that dead spot, the boom cylinder should be able to allow enough angle to continues the swing on the rake..
I have a landscape rake, but have not really used it that much. Does a landscape rake windrow like any other blades used at an angle?
Did you ever say where you purchased your tines, and how much they cost. I have lost a couple of tines, and plan to move some of them to fill the gap.
J_J said:
Larry,
WOW yes that's a brilliant idea - why didn't I think of that?
I'll have to let you know on that as soon as I try it out. I have been traveling all week on jobs. According to member Jimgerken, who built a really nice rake himself (to be featured in Farm Show Mag), says yes it will do that windrowing thing. (Page 4 reply # 33):
jimgerken said:
Larry, your pics are great. Glad I could help too. Yes, the rake angled does wonders. It does a great job of sifting out soil and moving rocks, reluctantly, to the side. I have found that going in reverse, with the rake angled also works, even without turning the rake around. Mine does not turn around. As you rake a trail, for instance, lets say its ten feet wide, the first few passes everything flows toward the side pretty well, but then the material builds up and the action becomes sluggish. At this point, angle the rake the other way (do not turn it around though), and back up. It will not sort dirt out in this mode, but the big windrow you made sure moves to the side nicely. When you get to the side of the trail, you can now also offset the rake, and keep moving the rocks off the trail, even while keeping your tire away from the edge of the trail, for safety.
If you dont angle the rake, you are gathering stuff till you have to dump it in a big pile. If you are angling, you are sorting, grading the materials off to the desired side of the trail/road, removing large rocks and leaving inch-minus.
I posted early on (page 1, reply # 10) I got the tines from Agri supply, they have three offerings - 1 hole Chinese for $2.09, 1 hole made in Italy for $2.99 and two hole made in Italy $2.99 ea. I used the one hole Italian ones :)
Agri Supply Rake tines
Larry
/ Landscape Rake Build #207
Larry
"I'll have the two hole Italian, on rye, extra peppers, hold the oil" ;)
:D :D :D
The rake tines bend an amazing amount when over loaded.
I have been lucky enough to bend one or two back into alignemnt with the others after "tweaking them".
Good ol spring steel.
/ Landscape Rake Build #208
GuglioLS said:
Renze - :confused:
Larry,
The dead point:
When you switch the hydraulic lever, from extension to retraction of the cylinder quickly, to continue the rotating motion. Thats where you find the dead spot. If the rake is not in motion, and you extend the cylinder, the rake may begin to rotate in either direction, clockwise or anticlockwise.
When there are four 1/2" bolts, i agree that it would more likely bend the cylinder rod than break anything else.
I find it hard to explain, but imagine putting paving stones inbetween existing pavement (like when you dug a utility line trench through existing pavement)
When you put the stones back, its going to be tight. What you'd usually do, is putting 2 stones up against each other like /\ and step on the middle where they meet. The more you push them down, the more force they will put on the existing stones pushing them aside, untill both described stones sit flat inbetween the existing pavement.
When the stones are pushed flat like described above, they will be at their dead point, and the closer they are to the dead point, the higher the force will be.
I dont know if you ever worked with paving stones ( they dont use them as much on your side of the Pond, i think) but it helps to imagine the force to the sides, the flatter the triangle gets.
Another analog is the rope tied between 2 trees: When the rope is 100 meter and the trees are spaced 10 meter apart, each tree will only have about 1/2 the force you excert to the rope.
But when the rope is spanned firmly between the trees, as short as possible (rope length as much as the tree spacing, tree is perfectly spanned in a straight line) either the rope will break or the trees will bend.
FINALLY a rake in action video. (~10 meg)
One of my twin daughters volunteered for the honors of taking the video:
I tried it in all cylinder positions, working them to their extremes by extending and retracting. It works smooth, and obviously did not fall apart, nor bend or break any parts, I didn't shear any bolts or bend any cylinders. :D (Sorry Renze) :p I still appreciate your metal bending tip, but your prediction of dire consequences for my rake have not materialized, :rolleyes: better luck next time. ;)
Below are a few shots of raked ground after initial raking, grass seeded then raked smooth:
Did you notice how tall and green the weeds are? We are in the middle of our monsoon season, so everything is growing out of control. I have not mowed or weed whacked since starting the rake project, so I better get after it.
Thanks for all your support, interest and ideas in this build it yourself rake project. :)
Larry
/ Landscape Rake Build #211
That video is fantastic!
Pulling & Pushing....and that was the people trying to watch the video! :D
The windrowing seemed to work especially well.
Thanks for all the pics and vids!!
Now go get those weeds trimmed up....heck, just rake them down. ;)
/ Landscape Rake Build #212
Larry,
Outstanding project. You have demonstrated your knowledge, workmanship, and quality control. The video says it all. It seems to work quite well.
TBDonnelly said:
That rake is poetry in motion.
Thanks for all the pictures and documention of the process. Oh...and did I mention the paint job. Great, great work.
Don
Thank you Don - yea that powder coating finish is amazing stuff.
LOL Thanks SkunkWerX - Hum, rake down all the weeds, now that's something I could sink my teeth into.
J_J said:
Larry,
Thanks J.J. - I appreciate that. It's hard for me to believe it's complete and passed field testing with flying colors. I'm gonna miss working on it, but sure do look forward to working with it.
Thanks Guys
Larry
/ Landscape Rake Build #215
Larry,
It wasnt a prediction, just a warning. :) No such thing as "bad luck" for me that it didnt fall apart, i just warned you to help you... It shouldnt be necessary to say that i was NOT hoping it would fail, off course not !
After watching your video, i think i've highly over estimated the forces on a landscape rake. (I've never seen a real one in our flat, rock free country, i just know them from TBN :D )
.... But do you really stand behind your statement of ramming it on either edge into a battleship, with the rake angled near its dead point ??? ;)
According to your video, for a landscape rake this construction will be fine. But if i use that construction on my scraper blade (still in preparation phase, moldboard has been made, havent found some frame beams yet to continue) to cut a deep ditch in offset mode with only the edge of the blade hitting the ground, in a sharp angle to bring up soil out of a deep ditch, with our 5245 (with loader roughly 3800 kg, MFWD) i would place my first-fail bet on the hydraulic cylinder...
I have a bale clamp for square, plastic wrapped bales on my front loader. It has a calculated clamping force of about 8 to 900 kg.
When i tried to push some bales into a bale stack that was dangerously leaning, i had the clamp opened so i pushed into the hydraulics. Result was that the front cap of the cylinder, busted out of the liner and i got an oily mess on those bales... From now on i put the 3rd function on my loader in float, so it pushes on the hinge, not on the hydraulic cylinder.
Its not the hydraulic forces that may, (MAY !!) cause damage, but the result of forces working on a very long arm, multiplied on a very short arm that bust cylinders.
So far my criticism, about what MAY happen in case of severe abuse :D
To correct any misinterpretations of my criticism, :p I'll just say it like the rest of the guys here: NICE RAKE !! ;)
/ Landscape Rake Build #216
Ok Larry I guess it's still raining because we haven't seen that rake work yet. Tell me you are actually going to use it!!! :D
But on a serious note, did you get the secret decoder flashlight key ring with your tines from Agri Supply? I re-found mine and here it is. Ok note to ASC..do not put little LED light, in an envelope, in a box with 30 tines. You can see it took some damage. I ordered 5 extra tines recently and will see if I get another.
Rob
/ Landscape Rake Build #217
Rob
I saw it working.
Go back to post #209 and click the video. Works great.
mjncad said:
I want one...now if only I had the shop to build one.
Excellent!
Thanks Mike - I read quite a few of your Tractor mods you post links to in your signature. I must say I am totally impressed with your aux lighting and cameras. The quality of wiring and circuitry would rival that of the Space shuttle - in fact I think your wiring is better and more reliable. Definitely not low bid construction.
Renze,
Dude, lighten up. Of course I knew you were not hoping my rake would break. You are a good sport letting me bust your chops like that. Just so you know, I'm a wise guy (Sicilian) so it's all good right? And no, I would not ram my rake into a battleship to prove a point - again over dramatization on my part of how strong I think the rake is. I would never think of using it at the bottom dead center point. Your suggestion to use caution is understood and well heeded - Thank you very much :)
:confused: :confused: :confused: What, are your blind too? :rolleyes:
Rob
Rob your cracking me up. Well no, I did not find my little decoder flashlight in my two boxes of 42 tines that were torn and falling apart. Of course I didn't look, was I supposed to? Oh thanks, now I feel like I got jipped. I did just order some stuff from them, (replacement quills, jack shaft, bearings, mower blades, belts and the like) for my little Murry hydrostatic 42" riding mower which I use for the tight spots around the house. I'll be sure and look for my surprise.
Larry
J_J said:
I saw it working.
Me too! I had a front row seat. HaHaHa.
RobJ - What J.J. Said
Thanks J.J.
Larry
/ Landscape Rake Build #220
GuglioLS said:
Renze,
Larry,
as an engineer, i have learned allways to look at worst case scenarios because in a warranty case, you cant debate lack of common sense - it just has to be fool proof because mostly you cant prove that the operator didnt follow the manual....
I just mentioned it, so it can be printed in your operator's manual ;)
I am in the trailer business for now... per september 1st i'll start as a wheel loader engineer !!! So in my new job, weight will no longer be an issue in my designs :p
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
Western 8.5 Pro Plus Ultra Mount (A62679)
Western 8.5 Pro...
Landa PGDC5-3500 (A64119)
Landa PGDC5-3500...
2008 CATERPILLAR D4K XL CRAWLER DOZER (A64279)
2008 CATERPILLAR...
UNUSED SDLANCH 14' PARTING IRON GATE (LION SCENE) (A64281)
UNUSED SDLANCH 14'...
