Landscape Rake Build
/ Landscape Rake Build
J_J said:
Larry,
Did you happen to notice any differences in the plasma cut holes from top side compared to the bottom side. ..........SNIP.......
Yes there is a taper, I am aware of that, I've had many project parts plasma cut, several for my friend Rob (3RRL), another friend and for myself. Most of it was 3/8" so the taper effect was not all that bad, any critical holes are undersized then later bored or drilled out. I used 1/2" plate for this rake build, I factored that taper into the index holes of my CAD drawings. Mostly what I wanted from the plasma cutting was the fancy curved parts, then bore or drill out critical holes to remove the taper.
Larry
/ Landscape Rake Build #102
Renze said:
I took the chance for the allmost new 3 cylinder pump. 2 months ago the motor burnt. Its a 4 hp 3phase 400V
A new motor would be 190 euro. Could you explain me what exactly are the parts that you ground smooth ? Maybe my compressor motor suffers the same, and i could fix it myself instead of buying a brand new motor.
I'm not really into electrical devices...
Renze, Our 3 phase motors are nothing like the "wimpy" 220 v motors in the States. :D I know that here larger (3-10 hp) "comunist era" motors are very inexpensive. I know several places where you can buy them for about scrap price--now that has gone up tremendously so maybe the motor prices also.:rolleyes:
Mike
/ Landscape Rake Build #103
J_J said:
Larry,
Did you happen to notice any differences in the plasma cut holes from top side compared to the bottom side. The reason I ask is that a plasma stream cuts in a small cone. A laser cuts better, and straighter. With plasma cutting the thicker the metal the worse it gets. I had some holes cut with plasma , and I noticed some difference. Anywhere from 1 to 5 degrees. On 3/4 thick metal, one side of the hole might be 1 inch, and the bottom might be 1 1/8 On thin metal, you will not notice much difference. This is just something to think about. It all depends on the cutting tip, whether it is new or well used.
Not entirely wrong nor entirely correct. Speed and amperage (or capacity) also have a huge effect on the quality of cut. Different tips will affect cut quality too. Hypertherm Powermax1000 Manual Plasma Cutter
/ Landscape Rake Build #104
Larry, I had no idea that sandblaster you have is that inexpensive? What a great tool to have around for all kinds of general tough cleaning like that.
Thanks for sharing it. I'll have to get one for sure now.:)
J_J said:
Larry,
Hi JJ,
Larry got several projects plasma cut for me.
The source he uses did a good job and Lord knows the price was certainly right. There is a taper as you describe and would vary depending. After receiving the first batch, I saw what you are talking about. On future projects I asked for only the cosmetic shapes to be plasma cut. Holes too, but only if cosmetic. I found holes that needed precision were better to get cut undersized, if done at all, so you can drill, ream or bore depending how close you want them. Not just hole size, but positioning also. I was worried about the "one edge" of the plasma cut holes wearing out my pins sooner. Plus they are kind of hard after being cut, so I use carbide to open the holes up since it is a little tough on hi speed. Still easier than starting a big hole from scratch though. And if size and location are not absolute, it's very inexpensive to have everything done.
How accurate, how straight is the laser cutting you talk about? What is the difference in cost, if any %?
Can you get a TRUE straight wall in a hole that doesn't need to be machined after laser?
Thanks,
/ Landscape Rake Build #105
Hi JJ,
Thanks,
This data is from a CO2 laser verses a plasma .
Minimum size of the cutting slit (kerf width)
LASER- 0.006", depending on cutting speed
PLASMA- 0.002"
Cut surface appearance
LASER-Cut surface will show a striated structure
PLASMA-Cut surface will show a striated structure
Degree of cut edges to completely parallel
LASER-Good; occasionally will demonstrate conical edges
PLASMA-Fair, will demonstrate non-parallel cut edges with some frequency
Laser cutting machines are very expensive. You can set up a Plasma cutting station for about $10,000
Oxy-Acetylene cutting is the least expensive.
Water jet is another method of cutting.
/ Landscape Rake Build #106
Larry,
Have you ever used one of those pressure washer sand blaster guns ? They will strip things down pretty fast. It works by sucking the sand into the stream and will suck up just about any size sand. I will try and find a picture.
/ Landscape Rake Build #107
Larry,
Practical CNC made up my plasma cutting table. I have everything ready to go except a place to put it. No garage. no shed, no nothing. I had thought about one of those shipping containers. I need 230 v for the Lincoln Pro-cut 55, and machine torch. Maybe one day soon.
PracticalCNC, makers of the finest plama cutters/routers
J.J. -
That pressure washer sandblasting attachment gizmo looks inexpensive enough. I would imagine sand mixed with a stream of water at 2400 psi might make short work out of a tough job. Does the metal rust from all that water?
Where do I get one? Does it fit all pressure washers?
Larry
/ Landscape Rake Build #109
Larry,
Better check on types of pressure washers it fits, I was saddened to find those types wouldn't fit my Karcher pressure washer. :mad:
They do a fantastic job, a friend has one. He took an old implement, i think it was an old disc, in about 15 minutes he had it entirely down to bare metal, took 50 years of rust off like that! Using regular white sand-box play sand.
If you leave the parts sit for days and/or weeks depending on your location and humidity you might get some surface oxidation, but nothing a quick hit with 220 paper or steel wool won't take care of quickly.
SkunkWerX said:
Larry,
Better check on types of pressure washers it fits, I was saddened to find those types wouldn't fit my Karcher pressure washer. :mad: .....snip.....
Bummer, that's exactly what I have, a Karcher. Maybe it could be adapted to fit somehow? Do I see another mod in the works :rolleyes: I've got one more huge part to blast, and I do not look forward doing that with my little gun. But will if it comes down to it.
Larry
OK here is a small update:
Finally got to do some welding on the TPH saddle mount index plate. In order for everything to line up, it was critical every part be square and true to the index plate, as well as the cylinder pin mounts and pin holes. 1-2-3 blocks were used to clamp the pin ears to the plate. If careful, no harm will come to the 123 blocks when welding.
Did you notice that 1" pin in the last three pics? The goal after welding was for that pin to slide in and out smoothly. Luckily it does, so I am please that worked out.
Larry
Esther took some time out to capture a few action shots of me welding. Don't you think those sparks look cool captured in mid air like that?
Larry
After the beer my welds started looking much better :D I took my Bosch 9" angle grinder to cut a bevel on the pivot bushing prior to welding into place. Then bolted on the arms that were bent with the "Larry-Renze" precision metal bender, those will be welded on next.
Thats it for this update. It's getting closer to mounting the plate on the tractor, finishing up the boom, attach the cylinders and rake tine mounting bar for a thorough check out. After that, I will take it apart and decide what the finish is going to be.
Larry
/ Landscape Rake Build #114
Did the welding sparks affect the taste of the Warsteiner? :rolleyes:
I swear that sand blasted metal almost looks like stone in some of the pictures due to lighting conditions.
Looking good, keep the pix coming.
/ Landscape Rake Build #115
Larry
Larry, I am not sure about adapting to the Karcher, however, I only gave it a fleeting thought. The more robust washers all use standard fittings, Karcher is proprietary.
I use one of these for blasting:
Harbor Freight 40 lb. blaster
It does a good job. I try to use slag as blasting media, whenever I can get ahold of some, great stuff. PlaySand for thinner material or surface oxidation.
My dad used on of these and was pleased with it.
But, it's not for large jobs.
/ Landscape Rake Build #116
Larry
Larry. About rusting.
As far as using the water sand blaster, after rinsing, I would spray denatured alcohol over the metal to help dry up all the water, and then spray a primer on the parts.
As far as the sand blaster not working with the Karcher, I believe it could be adapted. Some of the wands come with a plug in on the wand, and others come with a screw in attachment. I believe these will unscrew and interchange. I have both kinds, and an adapter to match up either part. Here are some adapters.
Karcher Sandblast Kit First image.
View Larger Image
KAR-22020 *Karcher Sandblaster kit
*Goggles included.
*Lance Length=22"
*Tube Length=10'
*Works great for cleaning barbeque grills and other general rust area around the home. $59.95 Yes
/ Landscape Rake Build #117
Good thing I had my welding helmet on when I looked at your photos.
Great progress Larry. No doubt there is a lot of prep work and set up behind the scenes. That is a big project when you consider all that you're doing. Thanks for keeping us in the loop with the stories and great pictures.
I know how time consuming just that part is, and I appreciate it and I'm sure the others do too.
/ Landscape Rake Build #118
Those welds look right decent. Hope you don't mind if we try and copy come of your projects.
/ Landscape Rake Build #119
They have opened a Northern Tool store in Jacksonville, Fl. I think I am going to like that. They carry a little bit of everything.
HaHaHa - Yes, after welding, the Warsteiner was Iron Fortified ;) Now that you mention it, the metal does look like stone. Thanks for the comments.
Larry
2012 Ford Expedition SUV (A61574)
2012 Ford...
Great Dane Van Trailer (A63689)
Great Dane Van...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
Prime 283 (A64126)
Prime 283 (A64126)
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2009 Wilson Hopper Bottom Trailer (A66285)
2009 Wilson Hopper...
