Landscape rake, bad and good
/ Landscape rake, bad and good #1
jeff_jeff
WA
Farm Pro 2420 (Jinma 200) & SVET46K Skid Loader, Raven MPV710 Mower
I decided to build a cheap landscape rake, based on the many prior TBN threads on the subject - I bought the tines from Agri-supply, and used the frame from my $100 Homier back blade. I mounted the tines on 4x4 lumber using 2" lag bolts - this set up worked great for about 10 minutes, until the 4x4 split in half - see attached picture.
So, I did what I should have done in the first place, and bought some 3x3 angle iron, and mounted the tines on that - everything works very nicely -
Total cost for the 4' rake was $91 for the tines, $8 in steel, and $10 in bolts and hardware - I already had the back blade and frame.
Here's a picture of the completed rake...
Also, you can see the reinforcement repair I made (previously) to the original Homier frame - I'm a big fan of Homier and the Farm Pro line - for light occasional use, the price just can't be beat
Jeff
/ Landscape rake, bad and good #3
Nice job. How much did you pay for the Homier blade? What did you use to drill all of the holes?
Thanks.
/ Landscape rake, bad and good #4
</font><font color="blue" class="small">( I decided to build a cheap landscape rake )</font>
Cheap?!?!!? That looks fantastic. I've wanted to buy a rake and now I may follow your lead...hey I have a 4foot blade that came with my Yanmar....maybe I will convert it to a rake....hmmmm
Great job...by the way how much dstance is between your tines?
Peter
/ Landscape rake, bad and good #5
Very nice project! Turned out real well! /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
And unless I missed it, looks like you accomplished it without the need to do any welding, which would make this something those without a welder could tackle.
Great idea. /forums/images/graemlins/smile.gif
The Homier Blade was $100 at their traveling road show - I used a drill press for the holes (a sharp drill bit is a must). I drilled the holes every 2 inches, so that 24 tines made a 4' rake. There was no welding, just drilling holes in the angle iron.
The reinforcement of the Homier frame contains a weld - the main pivot bolt comes attached to light (1/8"? or less) steel in the frame and ripped out after a couple of hours of use with the blade. I welded on a 1/4" steel reinforcment plate.
/ Landscape rake, bad and good #7
Jeff Jeff
What is Agri-Supplies address, and the part number for the tines.
I like that no weld idea. Excellent job, and lots of luck.
Bill
/ Landscape rake, bad and good #9
I built mine using the 2 hole 1" tines spaced 2" OC. Works quite well.
A point to consider. Do not order more than 18 at a time. UPS charges a weight surcharge and 18 is the max weight before hitting that limit. I placed 2 orders each on a different day. Thanks to a well informed customer service order taker I saved a bundle (over $50).
/ Landscape rake, bad and good #10
That looks real nice.
Where did you buy the tines? How does it attach? Can you post a full view photo? Thanks. G
P.S. Thanks for the UPS info /forums/images/graemlins/wink.gif.
/ Landscape rake, bad and good #11
TInes came from Agri-Supply. I have posted these before but here goes again.
/ Landscape rake, bad and good #12
One more.
/ Landscape rake, bad and good #13
The hitch end.
/ Landscape rake, bad and good #14
Last one.
