Landscape rake, bad and good
/ Landscape rake, bad and good #1
jeff_jeff
WA
Farm Pro 2420 (Jinma 200) & SVET46K Skid Loader, Raven MPV710 Mower
I decided to build a cheap landscape rake, based on the many prior TBN threads on the subject - I bought the tines from Agri-supply, and used the frame from my $100 Homier back blade. I mounted the tines on 4x4 lumber using 2" lag bolts - this set up worked great for about 10 minutes, until the 4x4 split in half - see attached picture.
So, I did what I should have done in the first place, and bought some 3x3 angle iron, and mounted the tines on that - everything works very nicely -
Total cost for the 4' rake was $91 for the tines, $8 in steel, and $10 in bolts and hardware - I already had the back blade and frame.
Here's a picture of the completed rake...
Also, you can see the reinforcement repair I made (previously) to the original Homier frame - I'm a big fan of Homier and the Farm Pro line - for light occasional use, the price just can't be beat
Jeff
/ Landscape rake, bad and good #3
Nice job. How much did you pay for the Homier blade? What did you use to drill all of the holes?
Thanks.
/ Landscape rake, bad and good #4
</font><font color="blue" class="small">( I decided to build a cheap landscape rake )</font>
Cheap?!?!!? That looks fantastic. I've wanted to buy a rake and now I may follow your lead...hey I have a 4foot blade that came with my Yanmar....maybe I will convert it to a rake....hmmmm
Great job...by the way how much dstance is between your tines?
Peter
/ Landscape rake, bad and good #5
Very nice project! Turned out real well! /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
And unless I missed it, looks like you accomplished it without the need to do any welding, which would make this something those without a welder could tackle.
Great idea. /forums/images/graemlins/smile.gif
The Homier Blade was $100 at their traveling road show - I used a drill press for the holes (a sharp drill bit is a must). I drilled the holes every 2 inches, so that 24 tines made a 4' rake. There was no welding, just drilling holes in the angle iron.
The reinforcement of the Homier frame contains a weld - the main pivot bolt comes attached to light (1/8"? or less) steel in the frame and ripped out after a couple of hours of use with the blade. I welded on a 1/4" steel reinforcment plate.
/ Landscape rake, bad and good #7
Jeff Jeff
What is Agri-Supplies address, and the part number for the tines.
I like that no weld idea. Excellent job, and lots of luck.
Bill
/ Landscape rake, bad and good #9
I built mine using the 2 hole 1" tines spaced 2" OC. Works quite well.
A point to consider. Do not order more than 18 at a time. UPS charges a weight surcharge and 18 is the max weight before hitting that limit. I placed 2 orders each on a different day. Thanks to a well informed customer service order taker I saved a bundle (over $50).
/ Landscape rake, bad and good #10
That looks real nice.
Where did you buy the tines? How does it attach? Can you post a full view photo? Thanks. G
P.S. Thanks for the UPS info /forums/images/graemlins/wink.gif.
/ Landscape rake, bad and good #11
TInes came from Agri-Supply. I have posted these before but here goes again.
/ Landscape rake, bad and good #12
One more.
/ Landscape rake, bad and good #13
The hitch end.
/ Landscape rake, bad and good #14
Last one.
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2014 Caterpillar 420F (A64126)
2014 Caterpillar...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
