l4200 remote hydraulics
/ l4200 remote hydraulics #1
ws105261
Hey all,
I recently removed the hydraulic top-link, side-link, and control valve from my Kubota L4200. This tractor was formerly owned by a landscaper and I didn't need/like the extra hydraulics.
After removal, I connected the supply and return hoses together making a 'loop' to bypass the control valve, but the fluid is still circulating through the hoses, and they get hot. Is there a way to completely turn off this hydraulic flow? I may use it later on but for now I would like to disconnect/bypass it.
Thanks
/ l4200 remote hydraulics #2
I'm not sure what to tell you about your hose setup, could you take a picture?
On a side note, let me know if you want to get rid of the top-link and/or side-link cylinders, I may be interested if the price is right.
/ l4200 remote hydraulics #3
Hey all,
Thanks
Short answer is NO, you can not turn it off. What you have is call the "power beyond" loop and is used for backhoes, logsplitters and valves. The easiest/cheapest thing you can do is to cover the hoses with something like this: Nylon Protective Sleeve (NPS) ,Any good local shop will sell it by the foot also.
Thanks for the info on the Nylon Protective Sleeve. There was a piece over the hoses for the FEL that needs to be replaced also.
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
(4) 265/65R18 TIRES & 5 LUG RIMS IN BOXES (A64278)
(4) 265/65R18...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
Kubota L3901HST
Kubota L3901HST
