l4200 remote hydraulics
/ l4200 remote hydraulics #1
ws105261
Hey all,
I recently removed the hydraulic top-link, side-link, and control valve from my Kubota L4200. This tractor was formerly owned by a landscaper and I didn't need/like the extra hydraulics.
After removal, I connected the supply and return hoses together making a 'loop' to bypass the control valve, but the fluid is still circulating through the hoses, and they get hot. Is there a way to completely turn off this hydraulic flow? I may use it later on but for now I would like to disconnect/bypass it.
Thanks
/ l4200 remote hydraulics #2
I'm not sure what to tell you about your hose setup, could you take a picture?
On a side note, let me know if you want to get rid of the top-link and/or side-link cylinders, I may be interested if the price is right.
/ l4200 remote hydraulics #3
Hey all,
Thanks
Short answer is NO, you can not turn it off. What you have is call the "power beyond" loop and is used for backhoes, logsplitters and valves. The easiest/cheapest thing you can do is to cover the hoses with something like this: Nylon Protective Sleeve (NPS) ,Any good local shop will sell it by the foot also.
Thanks for the info on the Nylon Protective Sleeve. There was a piece over the hoses for the FEL that needs to be replaced also.
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
2019 MULTIQUIP TOWABLE GENERATOR (A63276)
2019 MULTIQUIP...
2019 TAKEUCHI TL12V2 SKID STEER (A65053)
2019 TAKEUCHI...
