L3940 FEL lock lever ?
   / L3940 FEL lock lever ? #1
stub
Indiana
Kubota L3940HST, Kubota 7510HST (traded)
Was spreading some fill tonight and FEL up and down function became slower and slower and finally quit. Lever didn't feel right. No float position either. I quit and checked hydro fluid - OK, crawled under and checked linkage - nothing loose. Finally I worked the FEL lock lever back and forth and it freed right back up to normal. Lock must have worked itself slightly closed. Is it supposed to go down into the holes in the boot to lock open or shut? Mine is pretty stiff and doesn't go down. I guess I could lube it.
   / L3940 FEL lock lever ? #2
I have never used my fel lock and have never had it vibrate to the lock position. Philip.
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
JCB 2145 (A47477)
JCB 2145 (A47477)
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Case IH 496 Disk (A59814)
Case IH 496 Disk...
