L3650 shuttle shift problems
/ L3650 shuttle shift problems #1
Ole Orange
Ripley, Maine
L3650 DT GST & LA650A FEL
My L3650 DT GST is having problems now on a continuous basis with the forward reverse lever shifting.
From what I learned it looks like I might need to split the tractor. But I also found out I might be able to gain access by removing the transmission side plate.
I have already ruled out the linkage by removing it and just using the lever on the side of the tractor transmission. anyone out there have this problem?
Thanks for any help.:rolleyes:
/ L3650 shuttle shift problems #2
I owned a M4900 that had to be split because the Sync-shuttle got stuck in reverse. The syncronizer were worn out and had to be replaced. Reverser on your L3650 is similar to reverser on my M4900. My M4900 had been used on a dairy with 400 rs on tach when I bought it. Other than inspection I see little that could be done to correct your tractors problem through the side trans cover.
Thats what I was afraid of, I am pretty handy but not willing to take on splitting the tractor. just a note it dose not stick in forward or reverse it wont go into reverse when you have been in forward. another note if I plant the bucket down and roll it so the tractor moves like 1 inch it will slip right in. ???
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
210 Gallon Plastic Tank with Pump (A65640)
210 Gallon Plastic...
2005 GMC TOPKICK C6500 TESTING UNIT (A65643)
2005 GMC TOPKICK...
John Deere 772-A Grader (A62679)
John Deere 772-A...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
Ficklin 435 (A64127)
