L3000 won't start
/ L3000 won't start #1
DBLA
Florida
Kubota L3000
No lights on dash, won't preheat glow plugs, battery checks good (12.6v), short across solenoid does nothing
Ignition switch?
/ L3000 won't start #2
Safety switch. I did the same thing when I bumped the pto lever getting out of the cab and nothing would happen.
/ L3000 won't start
Found that battery was shorting out when key was turned on. Cleaned terminals and connectors, fired up!
/ L3000 won't start #4
All electrical troubleshooting should start at the battery, voltage at the posts is not a valid indicator. Voltage at the cable ends under load is much better. Tractors don't typically get "fuzzy" corrosion like cars do, they get a black corrosion that you can't see until you take the cables off and clean the terminals and posts. I never start any electrical troubleshooting without doing this first and testing the battery.
Brian
/ L3000 won't start #5
I have a much different tractor (a G1800) but I experienced similar symptoms last month. In my case, the lights would light up but the starter wouldn't engage. I won't go into everything I tried, but the problem turned out to be a bad battery ground cable connection. Try removing the cable from the chassis and lightly grinding down or cleaning the metal on the chassis and the cable connector. Even if that's not the problem, it's not a lot of work and costs nothing to do. If it doesn't work you will have at least eliminated one source of the problem.
2014 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
MAGNUM TRANSFER PUMP (A67714)
MAGNUM TRANSFER...
2023 KOMATSU PC490LC-11 EXCAVATOR (A65056)
2023 KOMATSU...
2018 DODGE CHARGER (A66091)
2018 DODGE CHARGER...
2019 MTD 42in Riding Mower (A66738)
2019 MTD 42in...
