L2900 Headlight Replacements? (LED)
/ L2900 Headlight Replacements? (LED) #11
No, with LED bulbs the wattage is high but its the amp draw is really low.
I have changed out all the incandesent bulbs on the tractor. before I changed out all the bulbs when I turned on all the lights the rpm of the engine would
jump a little due to the amp draw on the alternator., now it does not do it.
Here is a link to that post:http://www.tractorbynet.com/forums/yanmar-new/356265-incandescent-led-bulbs.html
/ L2900 Headlight Replacements? (LED) #12
Actually the wattage is also low, it's the output in lumens per watt of power or the efficiency that makes LEDs the hot ticket they are. Even a 5 watt LED puts out a heap of light. P=EI or Watts = voltage times current but operating voltage is also very low for LEDs.
I actually contacted an LED bulb supplier about 50W bulbs and this is what he said:
"The 50w leds only draw about 7 watts of power, so they will be far less draw than your present bulbs and stay cool to the touch when lit.
Explanation:
The led wattage is the max wattage rated of the leds in the bulb when driven at full power. Leds must remain cool when lit or they will fail, so high powered leds when driven at full rated power require massive heat sinks in order to draw the heat away from the leds. The P15d25-1 bulb is not large enough to fit a 50w heat sink, so to compensate, they must be driven at a reduced wattage to assure the leds do not overheat.
50 watts of leds at full power would produce more light than the brightest street lights, but that would require a heat sink as large as the largest street lights."
I think I'm going to get a multimeter on my 80W bulbs this weekend and see what they are actually drawing before ordering replacements.
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
Zero Turn Mower (A59231)
Zero Turn Mower...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2019 Deere 35G (A60462)
2019 Deere 35G...
1011 (A61165)
1011 (A61165)
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
