L2850DT - temperature gauge reading
/ L2850DT - temperature gauge reading #1
JTeague
Rock Spring, GA
Kubot L2850DT
Where does your temp gauge read when mowing? I run a 5' L&S Line bush hog with my L2850 ... which I think is sized about right for the equipment. I was a little surprised when the temp guage climbed to a little more than half-way between the 1st "notch" (operating temp?) and the 2nd "notch" (red/overheat). It never climbed much higher ... but that seemed a little high.
Conditions were:
Hmmm ... must have hit the wrong button ...
Conditions were:
* thick pasture (chest high)
* 85degrees +/-
* worked the tractor for a couple of hours before it climbed up
* did chase a few rats for fun ...
Is it normal to read that high?
Thanks for your input!
JT
BTW ...just hit 600hrs during the day!
/ L2850DT - temperature gauge reading #3
I have a L3450 the air flow thru the radiator is backwards (the fan blows forward). There is a screen behind the radiator. Check to see if it is clean
carl
carl
I guess I should have looked a little closer. I didn't realize I had a pusher fan! I checked the front of the radiator, which was very clean -- I was surprised it was so clean as a matter of fact. I should have caught that sooner.
Thanks Carl !
JT
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
1/4" Quick Attach Blank Plate (A66408)
1/4" Quick Attach...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A65643)
2017 FORD F-150...
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
