L2850DT - temperature gauge reading
/ L2850DT - temperature gauge reading #1
JTeague
Rock Spring, GA
Kubot L2850DT
Where does your temp gauge read when mowing? I run a 5' L&S Line bush hog with my L2850 ... which I think is sized about right for the equipment. I was a little surprised when the temp guage climbed to a little more than half-way between the 1st "notch" (operating temp?) and the 2nd "notch" (red/overheat). It never climbed much higher ... but that seemed a little high.
Conditions were:
Hmmm ... must have hit the wrong button ...
Conditions were:
* thick pasture (chest high)
* 85degrees +/-
* worked the tractor for a couple of hours before it climbed up
* did chase a few rats for fun ...
Is it normal to read that high?
Thanks for your input!
JT
BTW ...just hit 600hrs during the day!
/ L2850DT - temperature gauge reading #3
I have a L3450 the air flow thru the radiator is backwards (the fan blows forward). There is a screen behind the radiator. Check to see if it is clean
carl
carl
I guess I should have looked a little closer. I didn't realize I had a pusher fan! I checked the front of the radiator, which was very clean -- I was surprised it was so clean as a matter of fact. I should have caught that sooner.
Thanks Carl !
JT
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
2014 Kubota KX057-4 Mini Excavator (A61166)
2014 Kubota...
2017 Nissan Rogue AWD SUV (A61569)
2017 Nissan Rogue...
Sterling AT (A63118)
John Deere 1025R (A62177)
John Deere 1025R...
UNUSED SDLANCH 12' X 20' METAL LIVESTOCK SHED (A62131)
UNUSED SDLANCH 12'...
