L235 making oil
/ L235 making oil #1
jarcyn0
Kubota L235
Hello all, I have a late 80s model L235 with 700 hours that runs great, but has started making oil. Somehow diesel has started making it's way into the crankcase. From what I know, diesel either gets into the oil via leaking injectors or a leaking injector pump. Since the problem has just started in the last few hours of use and the tractor is still running an it has (no issues) where would exprerienced individuals recommend I begin narrowing down the source of the problem?
/ L235 making oil #2
Have u looked to see if it has a “supply pump”.??
Or called a “lift pump”.,
If its not black/white smoking, u can rule out the injectors..
/ L235 making oil #3
You seem overly convinced the oil has a fuel mixture. How have you confirmed that and eliminated hydraulic oil as another possibility?
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
Caterpillar 973/977 Traxcavator Parts and Service Manuals (A63117)
Caterpillar...
1069 (A64280)
1069 (A64280)
2024 MAHINDRA ROXOR OFF ROAD UTV (A64280)
2024 MAHINDRA...
