L235 making oil
/ L235 making oil #1
jarcyn0
Kubota L235
Hello all, I have a late 80s model L235 with 700 hours that runs great, but has started making oil. Somehow diesel has started making it's way into the crankcase. From what I know, diesel either gets into the oil via leaking injectors or a leaking injector pump. Since the problem has just started in the last few hours of use and the tractor is still running an it has (no issues) where would exprerienced individuals recommend I begin narrowing down the source of the problem?
/ L235 making oil #2
Have u looked to see if it has a “supply pump”.??
Or called a “lift pump”.,
If its not black/white smoking, u can rule out the injectors..
/ L235 making oil #3
You seem overly convinced the oil has a fuel mixture. How have you confirmed that and eliminated hydraulic oil as another possibility?
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
